Question about Lexmark P4350 All-In-One InkJet Printer
Cartridge error#1203 - Lexmark P4350 All-In-One InkJet Printer
  • 1 more comment
  • rickraynes Feb 06, 2009
    when i put in cartrige. i get this 1203 error on the black cartridge side
  • lilj60 Feb 21, 2009
    I've done everything, installed new black cartridge, still same message, and now copies in black, but not in color, but won't print off the computer, without the message everyone else has.
  • Anonymous Mar 29, 2009
    I HAVE A LEXMARK X 7170 ALL IN ONE PRINTER . JUST GOT CARTRIDGE ERROR #1203 . HAD B&W REFILLED AT WALGREENS , BUT COULDN'T REFILL COLOR ONE - FAILED ELECTRIC TEST . PRINTER DOESN'T WORK . TURNED PRINTER OFF/ON AND TOOK BOTH CARTRIDGES OUT & PUT BACK IN . GUY AT WALGREEN'S SAID MOST COLOR CARTRIDGES CAN'T BE REFILLED . I HAVE RE-MANUFACTURED COLOR IN NOW . lAST TIME I HAD SAME PROBLEM AND HAD TO ORDER A NEW ONE .
    NWASSUP1@AOL.COM
I have been trying to solve this problem all afternoon but the only way to do it was to change the colour cartridge even though the old one wasnt empty
Posted on Sep 20, 2008
Printer says error #1203 what do I do
Problem Error 1203 ; 1203 error message; 1203 cartridge error; Cartridge short error Solution Overview
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads.
Resolution
  • If the problem occurred immediately after the printer was purchased and unpacked from the box, please contact Lexmark Technical Support for assistance.
  • If the problem is occurring during the normal printer lifetime, the procedures below will help you to resolve it.
Troubleshooting a Communication Error between the Cartridge and the Printer click on this link and follow the steps listed, hope this helps! http://support.lexmark.com/index?page=content&id=SO3683&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X5495&searchid=1286737658844 Please leave rating ;) thanks
Oct 10, 2010 | Lexmark X5495 All-in-One &USB...
Printer says cartridge error: error 1203
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
Sep 06, 2010 | Lexmark X7170 All-In-One InkJet Printer
Cartridge Error # 1203 when replacing black ink cartridge
It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
Jul 16, 2010 | Lexmark X8350 InkJet Printer
Printer does not work. is Lexmark x4270 . I replaced cartridge and it shows on panel this message: Error #1203
There are 3 step to repair lexmark 1203 error
If you got lexmark 1203 error then there is a 94% chance that your computer has registry problems. To repair lexmark 1203 error you need to follow the steps below:
* Step 1 - Download a lexmark 1203 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair lexmark 1203 error.
Here are the url of lexmark 1203 error repair tool:http://www.fixerrorquick.com/ttfix-lexma… http://www.fixerrorquick.com/ttfix-lexma…
Jun 29, 2010 | Computers & Internet
Cartridge error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Hope it will work for you take care all the best Pineworks
Mar 13, 2010 | Lexmark X7170 All-In-One InkJet Printer
Displays Error Code 1203 - What is that? User Manual is lost.
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error 1203 What do I do?
Cartridge Error: 1203 Your print cartridge has a short.
  1. Press Power to turn your All-In-One off.
  2. Unplug your All-In-One from the wall outlet.
  3. Plug in your All-In-One.
  4. Reinstall the cartridges.
Aug 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Error #1203
Error #1203
A 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please carry out the steps below the image to confirm that this is a cartridge failure rather than a hardware problem
  1. Make sure the All-In-One is powered on.
  6. Check the operator panel to see if the same error has returned or if a new message has appeared.
    7. Check the operator panel. If the 1203 error is displayed, this cartridge is the defective item.
Mar 03, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark P4350 All-In-One InkJet Printer Logo
312 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
