My NeoPost SI-76 paper inserter is stating the collator sensor is dirty. Where exactly is this sensor? I cleaned every visible one but am still having the error. I fear it may be defective
  • 2072 Answers
SOURCE: Xerox Phaser 6250DP sensor not cleaning
Is there a specific code coming up? That can make it easier to pinpoint the exact problem.
Posted on Apr 21, 2008
NitrusInc
  • 326 Answers
SOURCE: I have a Dell W5300 printer. After removing all
Have you attempted leaving the printer unplugged (if possible in the on position) for a period of 5-10 Minutes?
Posted on Apr 13, 2009
dancandoit
  • 436 Answers
SOURCE: Sony CDX-CA400 FM/AM Compact Disc Player
The optic inside the CD player may be dirty or damp, this is the part that reads the data from the cd, you can try cd cleaning discs or you may have get an engineer to open it and clean it with an alcohol swab. The optic could also be faulty which will be cheaper to buy a new cd player.
Dan.
Posted on Dec 04, 2009
  • 34 Answers
SOURCE: Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Posted on Jan 21, 2010
ftw1952
  • 10319 Answers
SOURCE: Repair manual Neopost Folder inserter
here is the website to download your service repair manual
http://www.scribd.com/doc/36359094/Duplo-MD430-Service-Manual
Posted on Aug 29, 2010
Neopost si 68 stops after loading paper.
Go To Below official Canon Printer Page For Your problem
http://software.canon-europe.com/files/soft35401/Manual/Canon%20MP270%20_MP250%20series%20EN.pdf Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 12, 2014 | Office Equipment & Supplies
MX340 printer will NOT feed paper -- first sheet goes in about 2 inches and THAT IS ALL! This problem started suddenly -- all other functions appear normal. have even turned upside down and shaken to...
Two things you could try:
1) Your pickup rollers are dirty/worn:
Remove the tray, you should see either in the front or back some rubber rollers that feed the paper into the machine. These are much like tires in that they need thread to move the paper - if they're worn out, they need replacing - if they have a lot of paper dust or other stuff on them try to clean them with a moist lint-free rag. (Water only is fine, rubbing alcohol if they're bad)
Also look for a seperation pad, this will be a rubber or cork pad under the rollers. Clean this as well and if it's worn, replace.
2) A sensor is stuck or malfunctioning:
Run a page, make a mental note of where it stopped. Run another, did it stop in the EXACT same place both times?
Look in front of where the paper stopped, is there a small plastic flag right before the paper? Is it damaged or stuck? Try taking some canned air to that flag/sensor and try again.
Usually situations like these are either just simply worn/dirty rollers not feeding paper to the sensors in time or the sensors are damaged.
If neither of these resolve the problem then you may be looking at a solenoid issue or something else you wouldn't be able to repair on your own.
May 31, 2011 | Canon MX340 AllInOne InkJet Printer
Shows paper jam but no visible sign of jam
Open it up and follow the paper path. The paper sensor should be visible somewhere.
The paper sensor could be stuck, dirty or defective. Maybe covered in paper dust.
Apr 18, 2010 | HP Photosmart C5180 All-In-One InkJet...
Second hand Ricoh FT7950. Paper wont feed from
Going strictly from memory as this is an older model.
With the machine sitting ready to make a copy open the finisher door and close it . Are there any signs of life ie rollers spin tray moves stpler homes up?
IF yes I would look at the finisher entrance sensor as these get pretty dirty ith paper dust(or could be out of alinment from moving.
IF No then I would look at the finisher connector inspect for any damage .
Hope this gets you in the right area
Apr 03, 2010 | Ricoh FT7950 Copier
HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Jan 28, 2009 | HP LaserJet 3055 All-In-One Printer
240 error
24x errors are paper jam error 241 tray 1 242 tray 2 ect. this means that the paper does not make it to the timming sensor inside the printer. this si usually caused by dirty pick wheels on the autocompensator located inside the drawer on the bottom of the printer
Oct 08, 2008 | Lexmark T522 Laser Printer
Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Sep 11, 2008 | Brother IntelliFAX 4100 Laser Fax
188 people viewed this question
jasbo
jasbo
