Question about Mitsubishi WS48511 48" Rear Projection Television
Colors off Suddenly, my TV image goes back and forth at random between a normal image and one where the red and green is off-set dramatically making the image look horrible. I tried resetting the convergence automatically, but it didn't help. The image still switches from good to bad at random (every few minutes so far). Is this worth fixing or should I buy a new TV? We've had this TV (similar model, not sure of exact number) for about 4 years and just had a major failure of a larger screen diamond series Mitsubishi as well. We're not inclined to go with Mitsubishi again. Thanks.
I have the same problem, would like an answer.
Posted on Nov 10, 2008
Why did my Kolin DLT-3212M LCD tv picture suddenly go green
Are you connected with a box of some kind via the component input on this set? (red, green, blue connections?
If so unplug that box and wait--plug it back to see if the box will reboot and correct the issue--also you can try to swap green cable itself with blue for example and if then have BLUE issue that cable is bad.
May 20, 2012 | Televison & Video
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
HI i have an RCA HD52W59 and the picture looks 3D, I can use the manual convergence but when tv is shut off and turned back on it goes back to the 3D look and the auto convergence does not work - the...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 02, 2011 | RCA HD52W59 HDTV Projection Television
I have a 63' projection TV. The picture is off. All of the lights are working, but the images are fuzzy, and you see the image tripled. The three images overlap each other in red, green, then blue. ...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
69189a5.pngSOLUTION
May 09, 2011 | Philips 55PP9363 55" Rear Projection...
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Sep 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Color setting
MOST likely, use remote [maybe set] for <menu[setup]> <video>. This is normally where <brightness><contrast><color> and so forth live.
Jul 27, 2008 | Philips Magnavox 20MT133S 20" TV
Covergence Problem
What exactly are you seeing on the screen? If one of the colors is only slightly off, you should be able to correct it with the standard menu. If one or more of the colors has suddenly taken a dramatic shift, and is curved inward at a side, it means that one of your convergence output IC's has burned out. You should not attempt to realign the convergence if this happens because you will only be messing up all the settings, and when the new IC is installed, the picture will still be out of alignment.
Aug 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
Red & Green seem "off centered"
Your set uses the 195 series chassis, which has separate components for each of the 6 convergence channels and a separate power supply for the convergence circuits. If all 3 colors have drastically shifted, especially around the edges, then chances are your convergence power supply has stopped working. This is usually caused by the failure of the STK730-010 switching IC. If one of the colors has dramatically shifted by itself then something has stopped working on the convergence board. Sometimes I see CRT coolant leaking onto the convergence board as the cause. In either case this is something that should be repaired and realigned by someone experienced with RCA projection TV convergence circuits.
Aug 05, 2007 | RCA P46922 TV
Mitsubishi WS48511 48" Rear Projection Television Logo
246 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
