Question about Troy Xcd XCD INC TROY Serial Server TROY500 - terminal server ( TROY500-0031 ) (TROY5000031)
What i sthe factory reset procedure and default IP after reset? TROY500 serial print server
My print server cannot be reset to the factory default for some reason. I have tried holding the reset button for 10 secs, but without luck.
I have some devices where I have to hold the reset for 20 seconds. So try holding it longer. And make sure the print server is powered up when you do it.
Feb 17, 2016 | Belkin (F1UP0001) Print Server
Reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
Jetdirect ex default ip
Usually it it set to pick up IP from DHCP/BootP.
If someone had assigned a fixed IP and it is now unknown. It is better to reset the print server to factory default by pushing the little reset button,
Then check you DHCP server for the newly assigned IP address.
You will need a version of HP Jetadmin or HP webjetadmin to configure this print server
May 13, 2014 | HP JetDirect EX Plus Print Server
Brother DCP-J41100DW Ink absorber full message Showing
Troubleshooting
75
B
Machine Information
B
Checking the serial number
B
You can see the machine's serial number on
the Touchscreen.
a
Press (
Settings
b
Press
s
or
t
on the Touchpanel to
display
Machine Info
c
Press
Machine Info
d
Press
Serial No
e
Press .
Reset functions
B
The following reset functions are available:
Network
You can reset the print server back to its
default factory settings, such as the
password and IP address information.
All Settings
You can restore all settings to their factory
defaults.
Brother strongly recommends performing
this procedure before handing over or
disposing of the machine.
NOTE
Unplug the interface cable before you
choose
Network
or
All Settings
How to reset the machine
B
a
Press (
Settings
b
Press
s
or
t
display
Initial Setup
c
Press
Initial Setup
d
Press
s
or
t
to display
Reset
e
Press
Reset
f
Press
Network
or
All Settings
g
Press
Yes
to confirm.
h
Press
Yes
for 2 seconds
Nov 24, 2013 | Office Equipment & Supplies
Express EtherNetwork DP-301P+ Print Server: DP-301P+ how to resert the ip and password...
for you to reset to factory default you must have the original cd that came with it, it's called PS admin Version 3.0 the process takes a second to gain your Print server back to factory default.... if you want it reply to this with your email address i will forward the executable file to you...
May 17, 2010 | D-Link Express EtherNetwork DP-301P+ Print...
How to reset HP 1320N to factory default
Make sure you record your printer's settings before performing this procedure. Holding down the printer's Green print button briefly will print any configuration information.
a. Turn the printer power off
b. Press and "hold" the green "go" button whilst turning the printer on.
c. Continue to hold the go button for at least 5 seconds and until the amber
attention light turns on (triangle with ! in the middle), this should occur
before 15 seconds elapses.
d. Release the go button.
from http://www.pcreview.co.uk/forums/thread-2290821.php
The answer byteguy gave above would be the procedure to restore and HP Computer to factory defaults.
Feb 19, 2009 | HP LaserJet 1320 Printer
My brother printer MFC-640CW has stopped taking comand to print documents from my computer, i can copy and scan, but not print . ink pads are full.
Make sure the status and configuration of the print server. Check following:
1 Make sure that the machine is powered on, is on-line and ready to print.
2 Print the Network Configuration List of the machine and check if the settings such as IP address settings
are correct for your network. The problem may be the result of mismatched or duplicate IP address.
Verify that the IP address is correctly loaded into the print server. And make sure that no other nodes on
the network have this IP address.
3 Verify that the print server is on your network as follows:
For Windows®
(1) Try pinging the print server from the host operating system command prompt with the command:
ping ipaddress
Where ipaddress is the print server IP address (note that in some instances it can take up to two
minutes for the print server to load its IP address after setting the IP address).
(2) If a successful response is received, then proceed to Windows® 98/98SE/Me Peer-to-Peer print
(LPR) troubleshooting
. Otherwise, proceed to Step 4.
4 Reset the print server back to the default factory settings and try from the initial setup again. For
information how to reset to the default factory settings, see Restoring the network settings to factory in the manual.
Jul 01, 2008 | Brother Office Equipment & Supplies
DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server
You need to connect to it (using the broswer at the PC of same LAN with the current ip of the print server). Then click on Tools TAB, click on "Reset" at left. You should see "Do you want to restore this device to factory default setting?". Click on "Apply"
Jun 04, 2008 | D-Link DP 301P (DP-301P) Print Server
Old IP address
You can reset the MarkNet X2000 to factory defaults - which includes resetting the IP address to 0.0.0.0 like this:
1. Press and hold the Test button until all four lights stay lit simultaneously, then release the Test button.
2. When #3 and #4 lights light simultaneously, press and release #1 (the Menu button).
3. When #3 lights press and release #1 (the Menu button).
4. At this point the X2000 print server has been restored to the factory default settings and should have an IP address of 0.0.0.0.
-John
Feb 06, 2008 | Lexmark Refurbished MARKNET X2000 SERIES...
Setting IP Address
Really need a bit more information, like operating system for a start, but here goes: I am guessing that your subnet mask is different from your printers. What address that you set are you getting from the printer? On your PC, what is your IP and subnetmask set to?
Aug 10, 2007 | Osicom NetPrint 1000 Print Server
Troy Xcd XCD INC TROY Serial Server TROY500 - terminal server ( TROY500-0031 ) (TROY5000031) Logo
52 people viewed this question
Top Troy Xcd Computers & Internet Experts
David Payne
David Payne
Are you a Troy Xcd Computer and Internet Expert? Answer questions, earn points and help others
