Question about Sanyo DP50747 50 in. Plasma TV
I have a Sanyo DLP 50747. When I turn it on It clicks off in about 10 seconds. I read online to try replacing the sub-power board(part# SJ-B10N2010A) and if that does not work then replace the power supply board (part #LJ41-05246A) both of which I purchased from Shopjimmy.com. I replaced both and it still does the same thing. Can anyone give me any other suggestions?
  • 6 more comments
  • daniel_cl290 Apr 06, 2011
    It doesn't show a picture. Power light comes on for about 10 seconds. No picture. Then shuts off
    I copied and pasted that, it does not lead anywhere
    I have checked the fuses on the boards with an ohm meter. all check ok
    are these boards expensive? Would I be better off to buy a new TV?
    I did not see any LEDs on any of the boards
    I dont even see an LED
    I am at work now. When I get home I will check again and give you a response
  • 4,889 Answers
Sanyo plasmas have LEDs on the boards that can be used to identify the source of the problem. Are LEDs on any of the boards lit> If yes then which ones?
Posted on Apr 06, 2011
  • eagle338
    eagle338 Apr 06, 2011
    Do you see the LCD blinking or does it just stay in standby mode?
  • eagle338
    Sure thing. I meant LED. Not LCD sorry for the goof-up
    President:
  • 1,623 Answers
If you have replaced both boards and it does the same thing, then chances are that your first replacemnt the sub power board has blown again due to the main power board being faulty or the problem is not in the power supply boards and is actually the protection circuit of the tv shutting down as it detects a high voltage on one of the other boards. Is the picture good till it switches off, there are no ghosting or picture fading etc?
  • 5 more comments
  • Martin Murray Apr 06, 2011
    ok download this filehttp://ia600303.us.archive.org/32/items/...
    when its downloaded and the extension .zip to it so the filename goes from Sanyo-dp50747-Plasma-TV.omanual to Sanyo-dp50747-Plasma-TV.omanual.zip then extract the files. On both sides of the tv there are boards that control the power of the screen, i would center your diagnostics on these two. The included file shows where the fuses are located. Check the two fuses on the screen power boards to ensure they are not blown
    the picture you want is step 2 image 1 picture file in the Repairing-Fuse---Power-Board-2229 directory
    copy everything i just posted in the last comment
    the two boards i mention are your xsus and ysus boards this i believe is what is faulty on the tv not the power board
    Sorry but is 2.50am and i need to sleep. Hopefully you will be able to determine if power is reaching the left and right boards. Check the mosfets and capacitors for any damage . I will check back in the morning for any replies
    it all depends (price) can you reply with the part numbers on both boards
Hi, has a Canon IR2570CI copier. Shows error code E00748-4000 when trying to start the machine. What shall I do to make the machine start properly again. Best regards Klaus Garde Nielsen
Canon IR2570ci Error Code
Symptom
E732-0001
E747-DF00
E748-4000
Cause
Film coating preventing effective contact between Main Controller and Sub Main Controller SJ-A.
Main Controller PCB (Sub SJ-A)
Action:
Clean the contacts of the Sub Main Controller PCB (power circuit board)(SJ-A) using methanol.
Apr 29, 2008 | Office Equipment & Supplies
Sanyo dp55d44 replaced power supply,still doesn't work
The main board sends the on/off signals to the power supply board. You need a new main board. You can get it from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 06, 2016 | Sanyo Televison & Video
My Sanyo hdtv model dp 50747 turns clicks on and off but the power button stays on what needs to be done
Your TV is equipped with relays that turn it on and off, it also has a diagnostic circuit that runs a low voltage trough all the circuits to test them. If there is a problem with any of the boards it will turn the set off, thus the second click. The power light is just stand by voltage, waiting for the problem to clear. These diagnostic circuits are placed in a lot of electronic products to prevent further damage to the set. I would check my power board, especially look at the capacitors. If they (any of them) are bulging at the top then you are lucky that's your problem. If you are DIY'er get the Micro farad rating ie.[2200uf]
and x amount of WV (Working volts). They are dirt cheap on eBay or rob them from an old set. Try to put a higher working voltage (WV 35 VDC replace with 50 WV). Hope you get lucky and it's just caps, if not eBay or shop jimmy's is a good place to get replacement boards. I am just assuming it is the power board by the way you said it kicked off immediately.Good luck!
Gillight
Dec 03, 2013 | Televison & Video
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Sanyo plasma # 42840 will not turn on. swaped boards & it still does not work
Which board did you swap? I would first suspect the SC and SS boards first (or the x and y sustain boards) different termanology for different brands it seems. I would try the x main first. The easiest thing to do is unplug the power from the x main and then plug in the power cord, if it starts up, (you still wont get a picture but wont click.) you know its that board, if same result, try the y main.
Oct 02, 2012 | Sanyo DP50747 50 in. Plasma TV
Have a sanyo 50" plasma
This tv problems are related to powering up the tv and sustancening the tv power source to the tv itself.Replaced the tv sub power supply board where the a/c power cord plug into it.Try website like Ebay.com to buy a whole new refurbish sub power supply board for the replacement.
Sep 06, 2011 | Sanyo DP50747 50 in. Plasma TV
Sanyo DP50747 50 in. Plasma TV Logo
339 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
