Auto convergence disappeared from the menu on my 52" RCA TV, Model #R52WH73. This TV is just 1 week out of warranty and the timing is impeccable.
  • ValSki Jan 07, 2009
    I have an RCA rear projection TV Model #R52WH73 and I do not have the Convergence Option on my Menu Help?
  • 8,617 Answers
Replace FL231 that will bring back your convergence option in the menu. If the Fuse blows again, you will need the Convergence power supply board. If you need more assistance please let me know
Posted on Aug 06, 2008
SOURCE:
My convergence will not line up right
if you press menu then scroll down to setup then enter the setup menu does the auto convergence adjustment option still appear under the setup menu options or has it disappeared?
Feb 11, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Today, i went to mow the lawn and had left my tv and xbox on. when i came back, the screen saver on the xbox was on so i logged in my controller and the "modern warfare 2" title screen was...
Thats a very common problem with that model which happens when the flybacks bad solder joint causes an arc which blows the FL231, Diode DL231 and Capacitor CL230 on the deflection board. thats what causes the Auto convergence feature to disappear from the menu options. You can get the Repair kit called the convergence option missing repair kit from www.tvrepairworld.com its under the RCA repair kits category and contains the parts plus instructions for the repair.
Sep 05, 2011 | RCA R52WM24 52" HDTV Projection Television
How do I adjust the convergance? I have a shadowing problem
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from www.tvrepairworld.com which does contain the instructions.
Jun 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have a 56" RCA that i had the user manual for and lost it. i used to do the manual and auto converge. its been so long i forgot how to access it. help?
press menu then scroll to setup the auto convergence features are listed there. If they have disappeared you will need the ITC222A convergence option missing repair kit available from www.tvrepairworld.com
Mar 17, 2010 | RCA R52WM24 52" HDTV Projection Television
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
53inch RCA big screen tv , double vision...you asked me Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if...
Just press menu and then scroll down to settings and then under settings menu you should be able to see convergence. If not its disappaeared and thats a easy an inexspensive repair.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
My 52 inch rca tv has a convegence problem
is the auto convergence option still visible in the on screen menu ? Or has it disappeared? Let me know and I will assist you.
Apr 26, 2009 | RCA D52W23 52" HDTV CRT TV
I think that is the tv, it is HDTV. The convergence is off, and I can't find convergence on the menu. please help!
yesn However if your convergence has disappeared from the menu. et me know and I will assist you its a easy repair and parts with instructions will cost about 12.00
Apr 22, 2009 | RCA D52W23 52" HDTV CRT TV
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
Auto convergence
this point to the special fuse fl231 a small rectangular fusable link. .4 amps if you can get this fuse and you can solder repairs is not to difficult.. you have to resolder connections that cause this fuse to blow
Jun 20, 2008 | RCA HD52W58 52" TV
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
Ekse
