Question about Garmin nuvi 260W GPS Receiver
I have a Garmin nuvi 260. Just recently I lost my satellite connection. The little auto on the screen just has a "?" flashing over it. For some reason my home town is given as Olathe, KS. I live in Wisconsin. I tried resetting the GPS but when I try entering my own address it says: "no matches found".
    President:
  • 1,623 Answers
Open mapsource while the device is plugged in and tell it to restore your device, as it sounds like your maps have become corrupted
Posted on Apr 06, 2011
Computer doesn't find the garmin nuvi 260 gps
Download and install the usb drivers from the Garmin site.
Oct 01, 2016 | Garmin Nuvi 250w 255 255w 260 300
I dropped my Garming Nuvi 260 this past weekend and when I turn it on it goes to a screen saying Updating GPS Firmware 1% then jumps to Updating GPS Firmware Complete. It keeps popping up with these...
Inspect the bottom of your Nuvi 260. According to the owner's manual, some models have a small "Reset" button on the bottom. If yours does, you'll use this to reset the Nuvi 260.Press and hold the "Reset" button for several seconds, until the Nuvi powers off and powers back on. Next try
to slide the power switch on top all the way to the left to reset your Nuvi if it does not have a "Reset" button. Performing this action resets the system.
Next try a hard reset.
Slide the power switch to "Off."
Press your finger against the screen in the lower-right corner. Hold your finger in this position.
Slide the power switch to "On" to turn the Nuvi on. Continue holding your finger on the screen until the pop-up window appears. When it does, press "Yes" to reset your Nuvi to its factory settings.
Hope this works but dropping may have caused internal damage. If this does not work you may have to send it back to Garmin for service. I will attach a link for Garmin. Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/
May 30, 2011 | Garmin nuvi 260W GPS Receiver
Lost satellite connection
Please see this link for more information on this problem. Too much info to cover here:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Aug 05, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin nuvi 260 is only 6 months old and it can
First make sure you have the latest software in it.
If it does try a Master Reset.
Lastly, unless you're in a strange location with poor reception. Take it back. Or, it's still under warranty.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on your nuvi 260 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Aug 04, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Garmin nuvi system software missing 265W i try to update my garmin nuvi 260. I see on the screen: sytem software missing. I cannot do anything else. Please, help!
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Feb 22, 2009 | Garmin nuvi 260W GPS Receiver
Garmin NUVI 660 - can not locate satellite
Please read this solution, which might help you. On the 660, you press and hold the upper-left hand corner of the screen while turning on.
http://www.fixya.com/support/t1155473-garmin_nuvi_660_not_locate_sattelites
- Jim
Nov 06, 2008 | Garmin Quest 2 GPS Receiver
Garmin Nuvi 260
Check to make sure that the unit is not in demo mode. Go through the menus to find where the demo mode is located. Cycle it on and off.
If this does not work, I suggest calling Garmin tech support to find out if they have a simple solution.
In the worse case you will have to send the GPS in for service.
Jerry G.
Jul 01, 2008 | Garmin n?vi 260W GPS
Nuvi 260
Sounds like you did an incomplete firmware update. Go here:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp and do it again. It should fix it.
Feb 01, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
112 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
