Question about Motorola Mobility i836 Cellular Phone
Tmobile sim card unlock code
Anything to make the enter special code work please?
My t mobile phone samsung has a blank screen... driving me crazy.
I bought a new phone. Thanks tho :)
Posted on Aug 07, 2008
SOURCE:
I have a boostmobile simcard and i want to put the tmobile simcard inside the sidekick slide.but when i do it ask me for a special code is there a special code for me to start using it?
you actually need to unlock your phone to use the simcard not just a code. boost mobile and tmobile run and different networks to its not as simple as putting in a different sim card.
Mar 25, 2011 | Cell Phones
I want to use my att sim card in the Tmobile phone model SGH T-239,it says wrong card. how do I unlock it so i can use the phone...pls. help...my service provider is AT&T, I removed the sim from the...
Important: Stop if you receive an error message. The device may lock permanently if you enter the incorrect code multiple times.
  1. See if your phone is eligible to unlock: Mobile Wireless Device Unlocking.
  2. Contact Customer Care to request the Mobile Device Unlock code for your phone.
  3. Verify the IMEI by typing *#06#.
  4. Insert a Non-T-Mobile SIM & turn the phone on.
  5. The phone will automatically prompt you to enter the code into an empty field.
  6. Click/Tap in the empty field above the "Unlock & Dismiss" options (this will display a key pad on the screen).
  7. Input the unlock code provided by T-Mobile.
  8. Click/Tap Unlock.
  9. The phone will display Network Unlock Successful.
Feb 07, 2018 | Samsung SGH-t239 Cell Phone
MY PIN IS BLOCKED ON MY T-MOBILE PHONE WONT LET ME MAKE CALLS OR ANYTHING I NEED HELP
from the home screen you must enter a series of numbers and symbols. it is different for every SIM card, you MUST call customer or technical care to get what is called the PUK (Pin Unblocking Code). if you enter in the wrong PUK a number of times, the phone will automatically destroy the SIM card. whatever you do, do not try a code that someone other than T-Mobile gives you.
When your phone says that it happens because of security being set up on the phone or an attempt to set up security and not knowing the password...
if the password is incorrectly entered a number of times then it will completely lock up the phone having you call customer care to verify that its you that has the phone...
they have a special password they can give you to get that phone unlocked again
Aug 20, 2009 | T-Mobile Tmobile Cla Samsung Cell Phone...
I need a code to unlock my SGH-D415 t-mobile cellphone
HI HERE IS A SOLUTION CAREFULLY FOLLOW IT Warning: Do not enter any wrong unlock unlock codes on your Samsung SGH-D415 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-D415 mobile phone with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-D415 mobile phone is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-D415 mobile phone.
If it does not work, you can try these methods:
Method 1:
2 - ;;Phone;; will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-D415 mobile phone shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-D415 mobile phone.
3 - Compose : #0111*CODE#.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-D415 mobile phone.
Each Samsung SGH-D415 mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-D415 mobile phone at www.mobileunlocksolutions.com. HOPE YOU SUCCESSFULLY DO.... PLEASE RATE ME THANK YOU
Feb 19, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Phone freeze unlock code
FOR PEOPLE WITH PHONE FREEZE ON SAMSUNG- the #7465625*638*code# is not needed when you have the phone freeze just follow below.
I know how frustrating this was and i got it done by myself by experimenting since everything cant be googled that easily. i figured i can help anyone out. this has worked for 5 phones that i have done my self so 5 for 5 YESS!!! This is as satisfiying to me as watching micheal jordans final shot!
any ? contact me at [email protected]
ok i figured it out. for all those people that have gotten the dreaded phone freeze om samsung propel a767 or any other samsung phone so far not sure about touch screen.
first look for a local unlocker in ur area or somewher that can provide the codes and get the unlock code and phone freeze code. mine was only 20 for both and took less than 24 to retrieve. email me for his info.
insert sim that you want to use (tmobile). you get the screen which says phone freeze. type in the freeze unlock code which was given and the press the att logo/menu button.
**YOU WILL NOT BE ABLE TO SEE THE NUMBERS YOU ARE TYPING SO KEEP TRACK OF WHAT YOU INPUT**
after you have entered number and pressed button then you will get a network lock screen. this is where you type in ur unlock code. type that in press confirm and BAMM!!!! you are now able to use tmobile sim
Jan 01, 2009 | Samsung Propel A767 Cell Phone
How to unlock special SIM code on Sidekick LX (T-Mobile) from USA
works for sk 3, slide and lx.
the video says only at&t in the U.S. but... i've seen it work for fones in europe.
try it.
May 24, 2008 | T-Mobile Sidekick
Unlock Samsung sgh-t619
To get your IMEI no your mobile you need to use the following code *#06# This will display the IMEI number of your mobile
How to Unlock Samsung T619:
What you need to start is your Samsung T619 and a NON TMobile sim card. You can borrow a friend’s if you need one.
1 - Power the phone off
2. Remove the TMobile sim card
3. Insert the NON-TMobile sim card and replace the battery.
4- Turn on the phone, “wrong sim” should appear on the screen.
5-Dial *2767*3855# and wait. It could take the phone a few seconds to reboot. The phone will reboot,and the non T-Mobile SIM card in the phone will work,but this is only a TEMPORARY unlock step
6-Dial <span>*7465625*638*00000000*00000000# phone will say it is personalized.
7-Dial #7465625*638*00000000# The phone is now unlocked permanently.
8-Dial *#7465625# to check the lock status.
Apr 17, 2008 | Samsung SGH-T619 Cellular Phone
I need a special unlock code
More information please :)
Could be the PUK (Pin UnlocK code) which your provider will have. Could be a handset restriction code ie, if you are putting another carriers sim in a phone that is 'locked' to a specific carrier. Again, provider will help you with this on;
OR, could be anything, we really need more info, what screen, what is it asking, what are the surrounding circumstances.
Dec 22, 2007 | T-Mobile Sidekick ID Cellular Phone
Unlock code for T-Mobile Sidkick3
i have the PUK code to unlock t-mobile sidekick slide. buuuuuut, its not free. [email protected] if you would like the code please send $10 through paypal. if not, keep searching to find the PUK code.
Nov 27, 2007 | T-Mobile SidekickĀ® 3 Cellular Phone
Motorola Mobility i836 Cellular Phone Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
