Question about Maytag MMV1153B Microwave Oven
Microwave will not respond to most of the buttons. Unplugged for a minute or so and still not operating. Checked the 3 switches, and they are fine. Tried to set the clock and the 8 worked but not the 0. Some keypad buttons work but most don't. If I unplug it and plug it back in and wait for it to reset, I can heat up food by hitting the "add 30 sec" button as many times as I need, but once I open the door, I have to unplug and start over. Any ideas? I have the wiring diagram and schematic diagram, but don't know what to replace. Thanks.
SOURCE: Whirlpool microwave/oven model RM286PXV3
I have a 13yr old above-range oven which quit when my wife cooked food in an aluminized foil wrapper (a small fire ensued!). This oven has 3 thermal protection units, on the magnetron, the chassis and on top of the food cavity. This last one had failed open, and since it's in series with the magnetron thermal protection unit and the main relay, nothing would work. MAT electronics sell the units for less than $4, but my problem now is to pick one with the appropriate temperature cut-off. They range from 200 to 300F.
Posted on Nov 18, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a Whirlpool MH6130XEQ-0 microwave that doesn't heat food
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
If within the magnetron portion of the warranty (5-9 years) but out of the original full warranty (1 year), the manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a Whirlpool-authorized servicer.
You can find your nearest Whirlpool/Maytag-authorized servicer here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Mar 06, 2009
hardrocko
  • 1476 Answers
SOURCE: microwave won't heat food
I have a tip at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat which should solve your problem. It details what is wrong and how to correct it along with where to get the parts you may need. Let me know if you more help.
hardrocko
Thanks for using FixYa
Posted on Mar 03, 2010
Touch screen displays is lit up , but will not respond by touching any of the promts. I have unpluged the unit hopeing to reset no change. unit was working fine the day before.
HELLO.
The solution is to troubleshoot the microwave as explained below.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
please let me know the outcome..
thanks.
Sep 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Frigidaire FMV156DBA built-in over-the-counter microwave that started behaving erratically tonight. The light started blinking on and off, accompanied by a repeated beeping. I unplugged the unit...
Yes have it serviced. Sounds like there is a loose/corroded connection inside and loose connections can cause fires. The intermittent/ramdom operation is indicative of this.
Apr 08, 2011 | Frigidaire Over-the-Range Microwave
Whirlpool gold accuwave microwave oven lost power afer running em
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Accuwave Microwave Oven
Works fine before unplugging, stops working when plugged in again
Westinghouse WST3504 User Instructions Before Calling For Service
YOU CAN OFTEN CORRECT OPERATING PROBLEMS YOURSELF
AND TRY THE SOLUTIONS LISTED FOR EACH PROBLEM
Note: If the Microwave Oven still does not work properly, please contact Service and Repair
located on Warranty page. 19
BEFORE CALLING FOR SERVICE Possible Causes
• Is the power cord plugged in?
• Is the door closed?
• Is the cooking time set?
Feb 01, 2018 | Westinghouse WST3504 Microwave Oven
MAYTAGE MICROWAVE MMV5100AAB-SWITCHING BREAKER WHEN STARTING
is there a way to over ride the main board start button so i will know if the board is bad. or away to test this?.
Oct 29, 2008 | Maytag MMV5207A Microwave Oven
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
Microwave came on by itself
Yes this is usually caused by the touch assy, but $278 !!!!! Thats kinda steep considering the panel assy is only around 30-60 bucks!!! It will need the touch assy and even possibly the control board, because sometimes the logic IC gets fried and causes "ghost issues" as well.
Sep 17, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Maytag MMV1153B Microwave Oven Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
