Question about Ovens
Who can replace glass panel in lower door on a St George Model WEO-5 in Lower Templestowe.VIC. 3107. Paint on inside if glass has started to flake off.
3 Suggested Answers
  • 512 Answers
SOURCE: St George Oven Door - Glass Broken
http://www.sga.com.au/User-Manuals/default.aspx
Anyway that will get you to the right people.
Posted on Sep 20, 2009
rickead1
  • 1998 Answers
SOURCE: St George UEO-7 Inbuilt
ok how old is the unit there is a 2 year parts and labor warranty on that oven. I think that you must be in maybe austrailia if I am guessing correctly. Do you wish to repair the glass yourself? or do you wish to be put in contact with a repair company that will come to your location and fix the door for you? if you are looking for a company to repair here is your manual click here http://kleenmaid-appliances.com/use&care/FSR/SG_FSR/ueo7_ueo7r_ueo7s.pdf you would need to contact one of the distributors on page 80 of this link if you want to replace the glass yourself then you would still have to go through one of these distributors to obtain the glass but would save yourself the labor rate. I await your reply on my inquiries and look forward to discussing this matter as well as solving this issue with you. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks
Rick
Posted on Mar 23, 2011
It is a double oven, but I want to eliminate the lower oven... so, I am looking for an electrical plan so I can find out how to disconnect the lower oven... and only install the top part.
•Step 1
Open the oven door to the half open position. Locate the hinge on each side of the oven door toward the bottom. The top center of each hinge has a hole. Insert a nail or screw into the empty hole on each hinge to prevent the hinge from closing inside the door rail after disconnecting from the oven.
•Step 2
Grab the sides of the door with your hands and lift straight up to disengage the hinge from the door. Push down slightly on the top of the door to release it from the hinges. Pull the door away from the oven and place it on a flat surface with the door handle toward the floor.
•Step 4
Using a Phillips-head screwdriver, remove the two screws at the top of the inside door panel that secure the inner door panel to the outer door panel. Loosen and remove the three screws on the bottom edge of the oven door with the screwdriver. Lift the inner panel away from the outer oven door.
•Step 4
Loosen the two screws that secure the door handle to the outer door panel. Lift the outer door panel slightly to pull the handle away from the door.
•Step 5
Remove the screw at the top and bottom of the side hinge rails with the screwdriver. The hinge rails mount to the outer door panel and the inner panel sits between the rails. Lift the hinge rails off the outer panel.
•Step 6
Lift the inner door glass straight up out of the outer door panel. Stand the outer door panel up on its bottom edge. Pull the top trim off of the door panel and outer glass. Hold the top of the glass panel and pull the two side trim pieces away from the outer panel. Pull the outer glass away from the outer pan.
once it comes out you can do what u want.
Jul 27, 2010 | Ovens
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Jan 03, 2010 | Thermador SMW272 Electric Double Oven
Cannot find the model number of my oven and really need an inner glass seal. the model number is not in the manuel! help!!!!
look just inside oven door just below the cooktop/or look on top and just behind the rear control panel,or on back panel,or in lower pull out drawer of unit its one of those places
Sep 30, 2009 | Ovens
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
Whirlpool double oven - model RBD305PD82
Please take a look at the diagram if you think you want to do that.
if you still want to do it and need more details to disassemble feel free to email me. nguyen@ite.net
Jun 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
