Question about Pentair Whisperflo 1 Hp Pool Pump Wf-24 011772
Tried to backwash and now the motor just hums and I smell something burning. What now? Motor won't start now.
    President:
  • Pentair Master
  • 1,378 Answers
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
Start with the capacitor. Use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although It is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 08, 2011
My washing machjne won't do anything it filled up started to wash then stopped. Smells like something burning.
sounds like something may have shorted the motor or motor just burned windings , how old is it? did u hear any humming?
Dec 20, 2014 | Washing Machines
Kenwood fpm800 stopped
Hi, Like any washer if you smell something burning and a humming from the motor I suggest you take out any cloths in it and try turning the inside basket clockwise to see if it turns freely and if it does then the motor is defiantly shot but if it won't turn freely then either something is jammed between the inner and outer tub or the transmission if it has one is bad or the bearing housing is bad so try and disconnect the belt from the motor and see if the motor runs and if it does then follow from the motor to the tub and see what is frozen .
Good Luck
Gynoman
Sep 13, 2014 | Washing Machines
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Burning smell while washer fills
Sound like something else isn't turning because it's jammed
the the motor is trying to turn.
May also be the starting capacitor.
Oct 16, 2013 | Maytag Washing Machines
When I turned my pump off to backwash and then turned it back on it made a humming noise then stopped running. Now it is doing nothing. what could the problem be?
sounds like a bad start capacitor, or there is something (rock, sand, or some debris) caught in the impeller.
The start capacitor not working will cause your motor to hum, then it will overheat and trip the high limit. It won't attempt to come back on until it has cooled. It's a common problem.
try clearing the impeller first, if that doesn't work and the motor shaft spins freely, then it's a capacitor.
Jul 27, 2011 | Hayward Power Flo Lx
Humming sound and buring electrical smell
yes yes yes .you are absolutely right.its the coils in the motor burning.the motor needs replacement. Often the start relay for the motor sticks and makes the motor get too hot. This can cause the motor to over-heat and shut off on the built in safety sensor inside the motor. You may need to use a amp probe to test the motor properly, check model plate for proper amps.  If this is let go too long the motor windings can also be damaged ( they may look black instead of a nice copper color). The wires on the relay are also bad for burning off the wire terminals.   The wires at the motor should be checked to make sure they have not burned off or you can test the motor continuity with an ohm meter. See two newmotor wiring pictures.....here...and...here. The relay wires often burn off as well.
May 12, 2009 | Kenmore Washing Machines
Humming noise
humming is the motor powered up but not turning. burning smell is the motor overheating. cause may be the motor capacitor which is a cheap part. try replecing it and hope thge motor survived. could also be a foreign object in the pump impellor
Mar 13, 2007 | Zanussi 24 in. DE6744 Free-Standing...
Pentair Whisperflo 1 Hp Pool Pump Wf-24 011772 Logo
115 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
