Question about Canon Photography
Hi I have a Canon 500D and the camera, not the sd card, is is on card lock and I do not know how to remove it. I have looked in menu and gone to 'protect Images' and it says "Card write protected'. Are you able to tell me how to take the card lock off? I have moved the slip on the SD card which has not removed it. Thanks Carolyn
    Problem Solver:
  • 10 Answers
Hi Carolyn. There could be several reasons for locked card. 1. pin on side of the SD card must be in UP position, not DOWN2. Reformat your card via computer to FAT323. Card reader inside camera has one "little piece" inside for monitoring if the pin on SD card is pulled down or not. If this "little piece" is bent or broken, your camera could mean that SD card is locked. In this case easiest way is to return camera back to shop. Or if you like, disassembly camera, but you will lost your warranty.
Posted on Jun 12, 2011
Hi, i have a canon 500d trying to fix, thanks, when i put battery in even with power off, or power on, the blue lamp right of LCD stays on (does not blink), and no power on to the camera other than th
Check the HDMI, mini-USB, and SD card connectors for damage. The DC/DC board is part of the front board and it comes with the battery compartment. Check front and back of board for liquid damage and impact. Check SD card slot for damage to the contacts.
Nov 28, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Will using a SD card from another camera mess up my Canon? Seems ever since I borrowed a SD card my camera has been totally messed up.
As long as it is the right card for your camera you shouldn't have a problem. Try removing it and installing a smaller card, (make sure you power down the Camera 1st).
Dec 29, 2013 | Canon EOS 500D / Digital Rebel T1i Digital...
How do I correct Card write protected
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 19, 2013 | Canon EOS 500D / Digital Rebel T1i Digital...
Problem of the message Card write protected
Oct 15, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
Have a canon t1I EOS 500D camera that is showing a card write protection problem. Does it with any memory card I've tried so far. Any solutions?
The detection switch is either bent or broken. If you can see it you may be able to bend it back in position with a very small screwdriver blade. Otherwise the ASD circuit board the SD card unit is on will have to be replaced.
Oct 08, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon EOS 500D card write protected
Apr 06, 2012 | Canon EOS 500D / Digital Rebel T1i Body...
Does the camera have an internal memory?
The 500D doesn't have any internal memory for picture taking. It won't store any pictures unless you insert an SD card in the slot just above the battery on the right side of the camera (when you are looking at the screen)
Dec 04, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Card Write Protected
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
Nov 03, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
How do you format an sd memory card?
You should be able to use the camera's menu to format the SD card, just go into the setting menu to format it.
Also make sure the write protect lock is off on the SD card itself. To remove the write protect lock, take the memory card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab up to unlock it, it will be at the side of the card like this 59a6de4.jpg .
Regards.
Apr 12, 2010 | Fuji FinePix S7000 Digital Camera
Canon a590 Card (not really) Locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Jul 23, 2009 | Canon PowerShot A590 IS Digital Camera
Photography Logo
134 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
