Question about Lexmark X1150 All-In-One InkJet Printer
What size is the ink cartridge for a Lexmark Printer. Both Black and color.Thank YOU
    Guru:
  • 352 Answers
Depending on if it a 16 Black or 17 Black. The 17 is low capacity (12ml) the 16 is High Capacity (18ml) For the colour 26 (high Capacity) approx 6ml per colour or 27 low cap colour is approx 4ml per colour, From a refill point of view use less than this because the sponge looses adsorbancy with every refill.
Regards GM
Posted on Apr 06, 2011
bluenadas
  • 203 Answers
SOURCE: Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Posted on Jun 08, 2007
SOURCE: x5470 Lexmark printer
Just unplug the printer from the back and plug it back in. Problem solved. I did this on my mother's printer and it worked like a charm for this same error msg and issue.
Posted on Jul 07, 2008
SOURCE: lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
Posted on May 21, 2009
  • 104 Answers
SOURCE: Do I NEED 2 ink cartridges on the Lexmark 2500.
Yes you do need 2.
All ink cartridge bays has to be filled with a working cartridge, for the print driver to allow you to print. That is why I prefer single ink type printers, so it is not so expensive to maintain the inks you don't use.
Posted on Mar 10, 2010
  • 232 Answers
SOURCE: I refilled Lexmark ink cartridges 36 black and 37
36 and 37 can be refilled, but they won't work. They are "return program cartridges" as Lexmark calls them. That actually means that they CAN NOT be refilled. You need to buy 36A or 36XLA and 37A or 37XLA. Those are refillable.
Here is link to Lexmark's site, with a compatibility list.
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=Lexmark+X3650
Hope that helps!
Posted on Apr 15, 2010
What size ink can i use
You can use the 32 Black / 33 Color Standard yield cartridges or the 34 Black / 35 Color High yield cartridges on the Lexmark X5470 printer. Lexmark cartridges are available in most large office supply stores and online at lexmark.com.
Aug 11, 2011 | Lexmark X5470 All-In-One InkJet Printer
Thru cartridge out need to know what are the ink numbers for black/color
The compatible cartridges for a Lexmark Z640 printer are: #16 & #17 for black/mono and #26 & #27 for color. Thank you for choosing Lexmark.
Aug 09, 2010 | Lexmark Z640 InkJet Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
    I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
    Dec 24, 2009 | Lexmark X4650 InkJet Printer
    What type of ink cartriges are used in the lexmark 5400 model
    hello there
    here is the lexmark ink cartridges #31 for color and #32 for black 18c0031us_sm.jpg #31 Photo Color Print Cartridge (18C0031) $ 34.99 QTY 18c0032us_sm.jpg #32 Black Print Cartridge (18C0032) $ 24.99 QTY 18c0533_sm.jpg Twin Pack #32 Black Print Cartridge (18C0533) $ 47.99 QTY 18c0033us_sm.jpg #33 Color Print Cartridge (18C0033) $ 26.99 QTY 18c0534_sm.jpg Twin Pack #33 Color Print Cartridge (18C0534)
    Sep 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Is there a black ink cartridge compatible with my X2350 all in one?
    Nope, this printer uses lexmark one color cartridge, and the black color is generated combining the three inks in color cartridge.
    This printer will not work on a black cartridge.
    May 17, 2009 | Lexmark X2350 All-In-One InkJet Printer
    Lexmark x3430 need ink cartriage
    This is the only information I could find. Didn't your printer come with a black and color ink cartridge? If it did, all you need to do is take the ink cartridge out and write down the numbers written on the cartridge. The only ink cartridge I could positively confirm was the #24 color ink cartridge. The Lexmark website does not list any black ink cartridges for this model. This information was obtained from Officemax.com.
    Lexmark - 24 Ink Cartridge - Color
    Compatible with Lexmark Z1400 series, X3500 series and X4500 series printers;
    Lexmark - 23 Ink Cartridge - Black
    Compatible with Z1400 series, X3500 series and X4500 series printers;
    Sep 15, 2008 | Computers & Internet
    Compaq a3000 ink cartridges
    this printer is made by Lexmark and uses 12A1970 (black) and 15M0120 (color) cartridges
    May 14, 2008 | Compaq A3000 All-In-One InkJet Printer
    Colored Ink problem
    Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
    Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
    Nov 19, 2007 | Lexmark Color Z35 InkJet
    Colored Ink problem
    Jun 08, 2007 | Lexmark Color Z35 InkJet
    Lexmark X1150 All-In-One InkJet Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
