Question about Sony KDL-32M3000 32 in. LCD Television
When turning on tv picture looks like you have bad reception then after a few minutes picture gets clear, problem started a few months ago and tv was bought nearly 3 years ago. is this an indication of further problems later on or nothing to worry about?
  • alexjhilt Apr 06, 2011
    thanks, info confirmed what i suspected and because tv was bought from pricesmart in trinidad the tv was probably liable to faulter prematurely anyway.
    if i buy a new flatscreen what do you recommend?
  • 10,515 Answers
This is not a good news. There could be few probabilities, however more often on this set it is either faulty T conn board ( LCD control board ) or faulty mainboard. As it is already 3 years old, so it is already out of warranty. I would advise you to continue the TV as it is, however if the situations worsens, you need to call onsite technician to repair it. Be advised on most occasions, due to the cost of these parts, sometimes it is better to invest in used TV or a new TV.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 06, 2011
  • taran_2005
    taran_2005 Apr 06, 2011
    Thanks for your response!!
    If you are looking for a real bargain, look at the below link :-
    http://www.amazon.com/VIZIO-E320VP-32-In...
    Thanks and Regards
    taran_2005
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Vizeo plasma tv takes several time to start then picture flickers badly for a minute or two. After this, the TV comes on and functions normally until turned off. What should I look for?
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 18, 2012 | LG Televison & Video
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Nov 03, 2008 | RCA F32650 32" TV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Won't turn on
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualified service tech take a look because there are too many things that could be the root cause.
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Mar 21, 2008 | Samsung HL-R6167W 61" HDTV
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Sony KDL-32M3000 32 in. LCD Television Logo
265 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
