Question about Panasonic NN-S255 Microwave Oven
I need to know if there is a fuse on my panasonic genius inverter microwave.model NNS255w.if so where is it located? i thought I had looked everywhere? thanks!!
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Genius 800w locked
On many models, you press "Stop / Reset" three times.
A hard reset may help: Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can probably download it (or one that's very close) here:
http://panasonic.co.uk/customer-Support/download-centre.asp
If that doesn't work, you can contact Panasonic UK at http://panasonic.co.uk/customer-Support/svc-dealer-locator.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
SOURCE: Panasonic Microwave inverter oven model,
10 Amp fuse blown inside oven.
Posted on Apr 19, 2008
press start 3 times to lock and 3 times to unlock...hope that helps
Posted on Jul 11, 2008
welcomejee
  • 10594 Answers
SOURCE: panasonic genius microwave light bulb
Does your microwave front display lite?
Posted on Aug 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
The settings on my microwave appear fine. Then I set the time for let's say 50 seconds and it turns off in 5 - 9 seconds. Then what you see is the correct time --- no other message.
If this is an inverter oven, it could mean that there is a problem on the inverter board. Testing these boards is fairly simple. You just need to find a service manual for that model.
Jul 18, 2016 | Panasonic Genius Prestige Inverter...
No power to my Panasonic microwave
assuming u have pwr to the plug - and nothing lights up = it is probably a bad transformer - open thermal fuse.
WHICH was probably caused by a shorted mag, which means junk.
Feb 02, 2016 | Panasonic Genius Prestige Inverter...
Panasonic nn-sn778s microwave shuts off and no heat- H97 is error code
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Aug 21, 2012 | Panasonic Genius Prestige Nnsd997s -...
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 26, 2010 | Panasonic Microwave Ovens
I Need a replacement glass for a panasonic Inverter the Genius sensor model no#5A68160017 can anyone help as to where you buy this from
That's not the model number of the oven.
Check the tag around the control panel frame. It will be something like NNS-542BAW, etc.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 22, 2009 | Panasonic Microwave Ovens
My Panasonic The Genius microwave just stopped working not getting any power to display. Wondering if it is the fuse and where that would be located.
HI, if this unit is totally dead, this may be a power inverter issue. there is a fuse located on this board inside the unit. you will need to gain access to this board and fuse by removing the outer cover. there should be a few screws on the outside of the microwave to remove.
Check the In-line fuse for its value. if the fuse is good, replace the power unit(inverter board)
Jun 20, 2009 | Panasonic Microwave Ovens
Error code H-98
Dec 01, 2008 | Panasonic NN-P794SF Microwave Oven
Panasonic Model NNS768BA Genius Premier 1100W Display works - nothing else comes up H98
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 14, 2008 | Panasonic Microwave Ovens
Scrape or fix? Panasonic inverter genius sensor 1250 watt
In most cases, this is a problem with the inverter but it may be a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Dec 06, 2007 | Microwave Ovens
Panasonic NN-S255 Microwave Oven Logo
76 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
