Question about Sport & Outdoor - Others
I have a Bushnell Scope Chief VI and it needs the cover for elevation adjust. It's a 2.5 to 8 power. Where can I find one?
jaballou
  • 63 Answers
SOURCE: the top of my bushnell banner scope adjustment cap is broken
Google the model number and see if it is online anywhere. If not, you may have to vist gun shows, looking closely at old, "junk-filled" tables to find a "parts" scope or a replacement. In the long run, it might be wiser to get new scope, a Leopold would be the best, even if used. Good Luck!
Posted on Dec 06, 2008
SOURCE: Instruction manual for 1970's custom .22 scope with BDC
Hold the outer portion of the elevation knob and unscrew the screw on top. then pull up on the outer portion and you'll see a silver screw marked with an arrow and the word "Up". Sight the rifle at a known distance and then line up the knob with that distance as you push it down on the scope and replace the screw. I have one of these and figured this out on my own, however I'm missing the mount and would like some pictures and dimensions of the mount if any of you can get some. I'm gonna be machining a new one and would like to keep it as close to the original as possible.
Posted on Jan 22, 2009
  • 30 Answers
SOURCE: scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Posted on Sep 01, 2009
SOURCE: Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Posted on Oct 16, 2009
  • 32 Answers
SOURCE: i aser bore sight my Bushnell banner. I need to
if it is verry tight back it off a little bit you dont want to break the seal.i have never been a big fan of the laser bore sighters.i have had a cpl and both were inaccurate.BSA makes a good bore sighter for 49 bucks.try a cpl shots with it and find out how far you are truely off.remember 1 click is 1/4 inch.in 100 yrds.in the army we had all the ammo we needed to sight our rifles in.but here in the real world with ammo prices so high a good bore sighter is the way to go.
Posted on Nov 04, 2009
Need vertical cap for bushnell scopechief vi bdl 4x12x40?
I have a Bushnell Scopechief VI 4x12x40 bdc that was missing the vertical elevation dials. I called bushnell and spoke to a woman in the parts department who was able to help me out. She did a quick search of her inventory and stated, "that they had HUNDREDS in stock"! I quickly ordered 2 of each dial ($4.50 each) and 2 of there turret screws ($2.50). Shipping was $4.80. Definitely give them a call and good luck!
Feb 25, 2015 | Bushnell Optics
How to reset bushnell elevation adjustment to zero?
If you want to center the cross hair in the scope
Rotate elevation down to it stops then count up clicks to it stops then half number and rotate down that number then repeat with windage or you could use two v blocks and view a point through the scope and rotate scope and adjust cross hair until no deviation from a fixed point up or down left or right
Hope this helps
Dec 07, 2014 | Bushnell Optics
Keep having to resight scope
Sounds like they are right. The cross hair adjustment mechanism may be defective. I'd call bushnell and see what they can do for you.
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734 Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
Apr 08, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Bought a 444 Handi Rifle with a Bushnell 3200 firefly scope on it. Tried to sight it in at 75yds yesterday. I adjusted the elevation up 6 to 8 "inches" and I am not noticing any change. Still shooting low....
O.K Your gun packs a good kick, but you might try to first, tap the scope with the handle of a fair sized screw driver, after each adjustment. Next do not adjust it so many clicks at the time just 3 clicks and see if she moves the point of impact. Try a few clicks and tap the main shaft of the scope kind of rap it then shoot for group, fair 2 rounds to see if it has settled down, then adjust a few, tap and fire. work slow with a older scope and try to stock up on the bullets you decide to go with and zero for them. Any other round you use do not zero, but use go old windage to pratice with.
Oct 26, 2009 | Bushnell Elite 3200 Firefly 3-9x50 Matte...
Scope elevation adjusted allthe way up & still shoots low
Aug 23, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Bushnell banner elevation maxed out
It sounds as if your Scope rings are out of alignment or the front ring is lower than the rear ring. You may be able raise the bottom of the front ring by inserting a shim under the front ring base.
Aug 08, 2009 | Optics
Is this going make diffirents in at the Range or on the hunt?
Your problem is in the bases/rings. Remove the scope from the rings. Lay a straight edge in the bottom of the rings. The straight edge should touch both rings equally. If i understand you right, you have run out of adjustment up. If so, there will be a gap on the front ring. Verify that you have the correct bases for your rifle first of all. Then, depending on the rifle, you may be able to swap the front and rear bases/rings and correct the problem. Check alignment as above. NOTE: After rings are corrected, re-center scope elevation. Turn elevation screw on scope one way untill it stops. Count the clicks as you turn back to the opposite direction. Devide the clicks by two. Turn back the other way by that number. Your scope is now centered. Test fire at 25 yards. When close to zero, move back to 100 yards and fine tune.
Jul 04, 2009 | Bushnell Sportsman 3-9 x 32 Rifle Scope w/...
Cannot sight in riflescope for elevation, adjustment is maxed out
Try reversing the rings. Move the back one to the front, and the front one to the back. Turn your elevation adjustment, back to -0-, and start again.
Feb 01, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Scope out of elevation adjustment
If you are sure that the scope was mounted correctly to begin with, ie plenty of elevation left THEN you can install a slanted rail that will increase you elevation potential. Of course, that comes at the cost of having less elevation at the lower end.
A second solution is rings, like those by Burris with the plastic inserts. They have an accessory insert kit for these Signature Zee rings that will let you increase your elevation. Rings are ca 30 and the kit'll be ca 10, so 40 total.
If you're just missing a wee bit of elevation you could just lightly shim the scope in your current rings.
Nov 16, 2008 | Bushnell Banner Dusk & Dawn 6-18x50...
Sport & Outdoor - Others Logo
54 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
