Screen lights up and goes back off with power still on. Ex.: When powering up computer, screen will show page for a few seconds then disappear untill a differant page comes up, show new page for a few seconds and disappear again. Keeps repeating this action untill finally my desk top opens up on the screen. Desk top shows for a few seconds and disappears. I 'm left with a black screen from that point on. Monitor power is on the entire time and does not flicker. I've tried my computer with a differant monitor and everthing works fine. Have also hooked up the troubled monitor to a differant computer and it malfunctions in the same problem. Thank You Larry
    Problem Solver:
  • 15 Answers
Its not a software problem since the problem follows the monitor. I have found the filtering coils feeding the back lamp power supply (inverter) to be stripped of its coating improperly. The coil may be soldered into the board too deep causing the coating to be soldered in the through-hole. This causes a very thin connection and a crack develops. when the screen turns on the joint warms up and the screen backlight turns off because power to the inverter is disconnected. when it cools down it reconnects. this is a hairline fracture in the solder joint. this is the 12 volt dc + line to the inverter. The coil filters out high frequencies by offering impedance to any AC that may be present (interference, noise from nearby devices etc.).
If you are comfortable (and knowledgeable) with electronics repair you can remove the back cover and locate this coil. then slightly disturb it to see if your screen flickers on and off.
We received a shipment of these screens at work and 6 out of 10 had this problem.
Posted on Apr 17, 2014
    Guru:
  • 868 Answers
Hi Larry,
I see that you are having issues with you LCD monitor intermittently showing Video for a few seconds then just dies to a black screen and will show windows in the desktop then go back to a black screen again on the issue ...
I believe that what you are experiencing on the issue is a screen refresh rate setting in windows.
we will need to check you video settings on the system for the issue.
Before we go and change some settings on your system we will need to boot into safe mode first.
1. From Shut down as soon as you turn your system on keep on tapping the F8 key on-top of your keyboard, this will give you the Windows Advance Options Menu.
2. On the List Select Safemode once highlighted press enter once, a bunch o things will show up on the screen this means that windows is loading in Safemode and windows will be loaded but all drivers will not so may encounter a screen that has big Icons and letters on it which is normal.
3. Log-in you windows profile if you have a password setup, once logged in do the following instructions below.
Changing the Screen Refresh rate:
1. Right Click on your Desktop/wallpaper to get the pop up options menu, click on personalize.
2. In the personalize window click on display lower left side of the window
3. Then Upper Left side of the new window click on Change Display setting then on the next page lower right side you will see Advance settings click on it.
4. you will get a small window click on the monitor TAB you will see there a drop down for the Screen Refresh rate click on the drop down and select 59 Hrtz, then Click on Apply then OK to save the settings work on your monitor.
Posted on Apr 06, 2011
I have a gateway M275 when I power it up it shows Boot F10 F2 screen for about 3 seconds then goes to blank screen w/curser in top left corner. will not respond to anything. I do not hve the original disk
It seems like the computer is not doing power on self test. if it is not going straight to windows. Then there might be something wrong with one of the hardware components of the computer. I would advise you to take out the CRU's (Customer Replacable Units ex. harddrive, memory, MDC's) until you figure it out which component is bad
Apr 03, 2014 | Gateway M275 Tablet PC 141 LCD Display...
Start tast bar disappears
Right click (hit right mouse button) on task bar and click to lock task bar and uncheck hide task bar. If you cannot right click on time before it disappears move pointer to the bottom of screen and it should reappear. Than follow above steps. If all else fails restart computer clicking on the F8 key repeatedly until start menu comes up , choose safe mode and when the computer starts up your task bar should remain in place, follow above steps to unhindered it permanently and reboot the computer it will start back up in normal mode and your task bar should be "fixed"
Feb 05, 2013 | Lenovo ThinkPad T410 Notebook
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont display on the tv!!
Jun 10, 2010 | Sony PlayStation 3 40GB System
When my Pealr powers on the screen only stays lit few seconds
You can try a master reset which your provider will be able to provide the steps to you on how to do it, or the manufacturer's website. if a reset doesn't fix it than you need to get a new phone through your replacement options for this is a device issue.
Mar 14, 2010 | RIM BlackBerry Pearl 8100
Dell E152FP monitor after startup or coming back from standby the screen will show up and 5 seconds later it disappears. I turn off the monitor and turn it back on. The image comes back again but it...
Hello
Probably the monitor. LCD monitors use electrolytic capactors which change value with heat. The power board in yours probably has 6 to 8 caps whic need replacement. Take it to a reputable repair person or check out my websit.
Thanks
Jan 07, 2010 | Dell E153FP 15" LCD Monitor
What does the half moon lit up mean, No screen.
The half moon usually means the computer is in SLEEP MODE. Normally, pressing the spacebar will wake the computer up but I have noticed that sometimes, the computer can get "stuck" in sleep mode. If that is the case, you can hold the power button down (until the power turns off and the moon disappears). Wait a few seconds then hit the power button again to turn the laptop back on.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
Viewsonic VE170 dislay problem
Your LCD inverter is giving up. You can either buy a new inverter but its a bit expensive
http://www.lcdpart.com/Products/cpc1151r0015.html,
or you can have it fixed by some electronic expert.
Nov 19, 2008 | ViewSonic VE170 (Beige) 17" LCD Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
