Question about Jl Audio 1000/1 Car Audio Amplifier
Blown fuse I got this jl audio 1000/1 on one 13 inch w7 and it worked fine for the first day but now every time I turn the radio up it blows the in line fuse under the hood do anybody got any suggetions.
    Problem Solver:
It is prob your fuse you need at lest a 100amp
Posted on Aug 11, 2008
  • 631 Answers
What size fuse are you using?
Have you checked the speaker to determine if it's damaged?
Do the speaker and amp produce clean sound up to the point where the fuse blows?
Posted on Aug 09, 2008
I have a jl audio 12 w7-3 sub and it just stopped working and wont work anymore,what could it be?
Check your fuses on your amp power lead and amp or make sure your amp is turning on the should be a light somewhere amps can break more times then the sub. Check all your connections or check your amp and head unit settings most probably a fuse mine blow sometimes
Jul 26, 2014 | Car Audio & Video
My 12w7 has like a springing sound inside it, what is it?
Blown voice coil,,,,it was connected to a JL AUDIO amp correct? w7`s can ONLY be powered by JL amps due to ohm load.Advice buy a better quality sub,w7 is over-rated
Feb 07, 2013 | Jl Audio 13W7 Car Subwoofer
I need to wire two w 7 svc ten inch subs to a 1 ohm load
jl didnt make w7 svc but i will include a wiring schematic from jl for the w7......http://mobile.jlaudio.com/support_pages.php?page_id=145
Aug 26, 2010 | Jl Audio 12W3 Car Subwoofer
I have installed a 12" w7 and jl 1000/1 v2 amp. I was useing the bass knob untill i found out on the jl website that its not needed for this set up. I was haveing problems blowing 80 amp fuses so i went...
It is NEVER a good idea to increase the values of fuses . Chances are you have internally damaged your amp. The next time you are faced with this problem you need to find out why your amp is blowing fuses and not keep changing the value of the fuse.
Aug 20, 2010 | Jl Audio 12W7 Car Subwoofer
My cone on my JL W7 cone is cracked, How can I replace?
JL has good customer service, and usually you can get a drop-in replacement core/coil/former/spider. Call/e-mail the techsupport listed on their website, or contact your local dealer for replacement parts/service.
Jun 16, 2010 | Jl Audio 12W7 Car Subwoofer
Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Feb 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000\1 v2 and 13 w7
it depends on how you wired your 13 w7 did you wire the dual voice coils up or down?? the w7 comes with a book and it has the 1000/1 settings you need and then there is a guide that comes with your 1000/1 v2 and on page 14 it tells you how to set the gain accordingly to your ohm load for perfect sounds with little to no gain overlap (you can set the gain louder if you don't want maximum sq and are not worried about clipping cause a 1000/1 shouldn't blow a 13 w7 from overpowering only from clipping (and since the w7 are practically bullet proof clipping takes a long time)
Nov 06, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Blowing fuses
You will need to have the amp bench tested at full load to see if there is a pending problem. It will need to see with speaker loading resistors, how much current the amp is drawing and at different frequencies. if the amp checks out with the proper current, at the rated output, have the speaker checked out. Good Luck
Jun 15, 2007 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
199 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
