Question about Seagate ST320005EXA101RK 2 TB USB 20 Hard Drive
Hi there I hope you can help me out. I recently bought a Seagate ST320005EXD101-RK 2 Terabyte external USB hard drive. I have a windows vista setup on my laptop. I plugged in the harddrive and windows recognised the drive no problem. But whenever i try to copy a file to the Seagate drive, it hangs during the copy process, and I have to shut it down with task manager as it wont even let me cancel the process. Do you know what could be causing this? (Ps Although the drive was already formatted to NTFS I am now currently reformatting the drive and I will try again when it is complete.)
    Top Expert:
  • Seagate Master
  • 45,373 Answers
Have yo checked the compatibility of the drive for the hard drive to the win os
Posted on Apr 18, 2017
  • 4 Answers
SOURCE: External case removal, Seagate ST3160026A-RK External drive
You remove the foot/stand unit, then the silver cover with the circular rubber ring can be carefully pried off. If you do this, you'll void the warranty, so if you want to do this because your unit is dead, then you should return it for a warranty repair. If you're doing this to put a larger capacity drive in the box, be aware that larger or faster hard drives might generate more heat which could adversely affect the new drive's ability to operate properly.
Posted on Jun 23, 2007
SOURCE: system will not detect my Seagate ST3500641CB-RK 500gb external hard disk
My system is brand new, and completely protected with Macaffe, other USB drives are working fine, I checked Seagate External drive in other Vista and XP laptops, it is not detected in computer, as well I checked with even Device Manager, and UVCView.x86, it is not even showing as a USB device Connected.
Posted on Jun 07, 2008
SOURCE: Does Seagate Free Agent 1TB support Windows 2003 Server
No, it is a POS device. Take it back.
Posted on Jun 26, 2008
SOURCE: New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Posted on Nov 19, 2008
  • 17 Answers
SOURCE: my seagate external HD is not recognised. WHIRR sounds instead.
Go to:
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-001&h_lang=en&h_cc=us&h_product=96120&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
select your exact model and download the drivers you need
Posted on Dec 27, 2009
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.em?
Sounds like driver problem to me. Re install the driver by using installation disc, or if you have lost your CD, than use this Driver Update Software to update. I hope this helped.
Brian
Oct 24, 2012 | Seagate Expansion 1 TB USB 2.0 Portable...
I just upgraded my Windows Vista 64-bit computer to Windows 7 64-bit. Backed up all my documents onto a ST3200823A-RK Seagate external hard drive. I have used this HD for 3 years, and it has always...
if you external hdd does not work on any other computer other than yours . try opening it with a linux OS. u can Ubuntu live cd .. boot from it and run it live...connect your HDD .. i hope you can see you files then >>> good luck
Jun 20, 2011 | Seagate 160GB 3.5" External USB Drive 160...
ST3250824U2-RK hard drive letter problem
make shure you plug the unit into a usb 2 compatible socket on my machine one of the ports is classed as a usb 2 hum try other ports
Jan 17, 2010 | Seagate (ST3250824U2-RK) 250 GB USB 2.0...
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
Seagate free agent 1.5 terabyte will not stay connected to my computer When I connect my free agent to my computer (Asus laptop with Vista Home premium) all the folders show up and I can access files for...
Check the HDD on a different USB port. It there is still problem, try that with a different computer. If it still shows this issue, try changing the USB cable. If the issue persist, its your HDD.
Jun 06, 2017 | Seagate Free Agent Go Small 12 GB USB...
Can't see Seagate external hard drive on Vista devices with remov
dougv52
If the drive is not showing up in My Computer but is showing in Device Manager then you most likely need to assign a drive let you the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 21, 2008 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Win 98
You would need two set of driver:
  • motherboard USB drivers;
  • mass storage driver from Seagate for Win98.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
System will not detect my Seagate ST3500641CB-RK 500gb external hard disk
if your system some virus hope it is not read......better you try any other some card reader or pen driver if it read you try other OS ....
Jun 07, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Seagate ST320005EXA101RK 2 TB USB 20 Hard Drive Logo
48 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
