Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
How can I clean /remove muffler & spark arrester on my ryobi cs30-ry30120 ?
    Novelist:
  • 111 Answers
There are two torx head screws in the muffler. If you take these out the muffler comes apart.The first thing to come off is the outer cover of the muffler. After that there are 3 more screws (the part description only says pan head) that hold the outlet tube on, under this outlet tube is the spark arrestor screen. You can clean the screen by heating it up until the carbon on it turns a red/orange color, then blow the screen clean. I would suggest a propane torch from Wal-Mart and a pair of pliers to do this. Then re assemble the muffler. I have included a link to the Ryobi Parts breakdown. http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF You may have to put your RY30210 model number in the search box. The diagram you are looking for is the Engine Assembly. I hope this gets you back to running again. :)
Posted on Apr 06, 2011
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Starts easily, but won't rev for 10 mintues. After warm, max speed is low / lacks power. New plug & gas filter
Check to see if the muffler is blocked.There is a screen (spark arrester) at muffler exhaust these get blocked. Usually 1 screw holding it in. Remove screen and replace or clean. I use bernzomatic torch to burn out these deposits.
Oct 01, 2010 | Husqvarna Forest & Garden 125bt Backpack...
I have a Ryobi brushcutter that is 4 years old.When I was using it the other day it just would not run at full throttle. I checked spark plug,air filter and fuel filter. No adjustments on carb. I have no...
Smokey 2 cycle oil will cause the exhaust ports to carbon up and plug the spark arrestor.
Remove the muffler, use a pick to clean out the exhaust port on the engine, and the muffler inside opening, then clean the spark arrestor screen, to assure yourself you are correcting the problem start the machine up with the muffler off, it should run like a charm, if it goes back to running badly when you reattach the muffler it may be clogged on the inside.
Jun 14, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Jun 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi CS30, will start but when I pull on the throttle trigger it bogs down.
i had same problem. i did a few things - cleaned muffler, replaced fuel line and filter (home depot sells a $7 kit) and in the past i replaced the head casket.
Mar 13, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Getting spark but will not start
check to see if spark arrester in muffler is stopped up, my weed eater stopped running so i had to remove the screen in the muffler
Sep 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Aug 17, 2009 | Honda 6370C - Parallel Power Kit For ...
What is the fuel mixture on the ryobi cs30 weed eater?
Mine says 50:1 on the gas cap. It's a 2006 CS30. Model #RY30120.
2.6 oz of 2cycle oil to i gallon of 89 octane fuel is what i use and have no problems
Jun 30, 2009 | Ryobi Three Trimmer Combo
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,115 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
