Question about Canon L90 Fax
Disable ECM on canon fax L90 - Canon L90 Fax
2 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: When i send a fax from my Canon L90 the receiver
Have the receiver set their paper to portrait. 8 1/2 x 11. Their machine should be able to figure this stuff automatically.
Posted on Feb 02, 2010
If copy quality is very dark then what to do for making it normal
The dark quality is definitely linked to a light intensity problem. If the scanner lamp is operating properly then check for any reflective surfaces near the scanning lamp and clean those. It only takes a light film of dust to make copies dark. Be careful around the lamp, it is delicate.
Jan 26, 2015 | Canon 2234B007 - Faxphone, L90 Laser,...
How to disable ECM and Reduce Baud rate for Canon MF4270 G3 Fax ?
Your approach is correct however it doesn't look like the MF4270 provides for these settings. One might expect to be able to select G3 or ECM or set a lower TX speed.
I located the settings for different Canon Fax machines here:
VoIP Fax Settings
Jul 25, 2014 | Canon imageCLASS MF4270 All-In-One Laser...
Can you please tell me how to print Fax activity report each time? means whenever I send a fax I need confirmation receipt thats its gone through.Can't find anything in Manual.
ACTIVITY REPORT
The FAX is factoryset to automatically print an ACTIVITY REPORT after every 20
transactions. If you want to print an ACTIVITY REPORT before it is automatically
printed, follow this procedure:
Transactions in an ACTIVITY REPORT are listed chronologically.
1 Press Function.
2 Press Report.
3 Press OK.
• The FAX prints an ACTIVITY
REPORT.
• If you prefer the FAX not to print an ACTIVITY REPORT after every 20 transactions,
disable the ACTIVITY REPORT setting ( p. 145).
• Please note that only one transaction number (TX/RX NO.) is assigned when you send
a document to several fax numbers in one operation.
ACTIVITY REPORT
PRINTING REPORT
27/12 2002 15:00 FAX 123 4567 CANON 001
ACTIVITY REPORT
ST. TIME CONNECTION TEL CONNECTION ID RESULT
* 27/12 13:43 905 795 1111 Canon CANADA 5001 AUTO RX ECM 1 OK 00'33
* 27/12 13:45 905 795 1111 Canon CANADA 0001 POLLING RX ECM 0 OK 00'00
0 STOP
* 27/12 13:51 03 3758 2111 Canon TOKYO 0002 B'CAST ECM 3 OK 01'18
* 27/12 13:53 2 887 0166 Canon AUSTRALIA 0002 B'CAST ECM 3 OK 01'18
* 27/12 14:10 905 795 1111 Canon CANADA 5002 AUTO RX ECM 1 OK 00'18
* 27/12 14:16 2 887 0166 Canon AUSTRALIA 5003 AUTO RX ECM 4 OK 03'59
* 27/12 14:27 20 545 8545 Canon EUROPA 0003 DELAYED TX ECM 1 OK 01'20
27/12 14:30 20 545 8545 Canon EUROPA 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:31 03 3758 2111 Canon TOKYO 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:57 2 887 0166 Canon AUSTRALIA 0005 TRANSMIT ECM 3 OK 01'25
0 STOP
27/12 14:59 1 432 2060 CANON OPTICS 0006 TRANSMIT 0 OK 00'01
0 #018
go to this site to download manual (see page 11-3)
http://files.canon-europe.com/files/soft30110/manual/FAX_L220_L295_UG_ENG.pdf
Dec 16, 2010 | Canon L220 Plain Paper Laser Fax
When i send a fax from my Canon L90 the receiver is getting it in landscape mode.
Feb 01, 2010 | Canon FAX-L350 Plain Paper Laser
Model L90 -- the incoming fax alert is too loud.
Press the dataregistraion button go to usersettings press set button press the arrows and scroll to no 9 Volume controll there you can change the alarm volume.Some models volume controll dial is on the left side of the key pad.
Dec 02, 2009 | Canon FAX-L900 Plain Paper Laser
I have hp laserjet 3050 and i not able to receive fax
Hello Rupesh,
Following is the description for Error 232
A communication failure (comm error) has occurred between the two machines. OR The user at the remote machine may have pressed CANCEL. OR The power at the remote machine has been interrupted, or deliberately turned off, causing the fax session to be interrupted
  1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
  2. If the error persists, and error correction is in use for the fax session, disable ECM
Disable V.34 on local machine V.34 is the modem protocol used by the product to send faxes. It is the worldwide standard for full-duplex modems sending and receiving data across telephone lines at 1,200 or 2,400 bps. The default setting for V.34 is ON.
Follow the steps below to disable V.34 setting.
  1. Press Menu/Enter.
  2. Press the < or > buttons to select Fax Setup, then press Menu/Enter.
  3. Press the < or > buttons to select All Faxes, then press Menu/Enter.
  4. Press the < or > buttons to select V.34, then press Menu/Enter.
  5. Press the < or > buttons to select OFF, then press Menu/Enter to save the selection.
top
Disable or Enable the ECM
  4. Press the < or > buttons to select ECM, then press Menu/Enter.
  5. Press the < or > buttons to select OFF or ON, then press Menu/Enter to save the selection.
    NOTE: The default setting for ECM is ON.
Dec 20, 2008 | HP LaserJet 3050 All-In-One Printer
Canon L90 Fax Logo
390 people viewed this question
old marine
old marine
