Question about Whirlpool GI5FSAXVY Stainless Steel Bottom Freezer French Door Refrigerator
The frig part is freezing everything in it. It is set on the highest setting 46. It is a whirlpool gold gi5fsaxvy. Is there anything I can do to fix it w/o calling a repair person?
    Problem Solver:
  • 19 Answers
Sounds like the thermostat is bas should be under a cover inside at topp !!
Posted on Apr 06, 2011
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
I have a Whirlpool GI5FSAXVY. The vegetables are freezing in the vegetable bin located under the ice maker. I set the tempture to 40 degrees and the problem continues. Can you help correct this? Thank you.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Also check the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this will helpout in solving the problem..
Jun 14, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
Our Whirlpool GI5FSAXVY refrigerator is freezing items. The temp control has been set to 38 degrees forever. It appears that things on the lower shelves are freezing more than things on the upper...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 12, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
I have a Whirlpool Gold refrigerator w/french doors, model GI5FSAXVY. The door on the right is set higher than the other, not allowing me to open my cabinets above. How do I adjust the height of the one...
you might be able to get a little room
look at the bottom hinge of the door
the one you want to lower
you should see a few spacers between
the bootm of the door and the top of the hinge
as well as being able to lower the hinge pin by screwing it down
Oct 11, 2009 | Whirlpool GI5FSAXVY Stainless Steel ...
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
GE GSS27RGMFWW Freezer Not Freezing..
Hello. I just now found your post here on fixya. Do you still need help with your frig?
Oct 16, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung RS2545SH Freezing Everything
Sounds like a thermostat problem. There will be a thermostat sensor inside the fridge usually inside the interior light housing.
Sep 26, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Whirlpool GI5FSAXVY Stainless Steel  Bottom Freezer French Door Refrigerator Logo
215 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
