Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
How do i clean the water valve? - Frigidaire FRS3R5EMB Side by Side Refrigerator
    Problem Solver:
  • 19 Answers
You have to replace it u can try n blow it out with a air compressor but more than likey ull have to replace it
Posted on Apr 06, 2011
Not heating water
see this causes and fix it. God bless you
Water Inlet Valve
First you will need to completely remove both hoses. Check and clean the screens in the hoses. Next look in the back of the water inlet valve the screens can usually be pulled out and cleaned. If all is clean and still no water, check to make sure the water inlet valve is getting power when the washer is in a fill cycle. If it does replace the water inlet valve.
Sep 28, 2012 | Washing Machines
Tip
How to Clean Hot Water Heater
You may just think that you need to clean it out or you may be getting cloudy dirty water from it. Anyway, you want to clean out the hot water heater but have no ides how to do it.
Here are the steps you need to take to get the job done.
Before beginning it is a good idea to have a new pressure and temperature relief valve and a new drain valve on hand to use if needed. If you don not have a valve on your cold water line going into the hot water heater then you need to install one or have one installed.
First you need to shut off the gas or electric to your hot water heater, which ever way you heat your hot water.
Next hook up a hose to the bottom drain valve of the hot water heater. Run this hose outdoors or to a floor drain.
Open the drain valve to start the water flowing out of the tank. The relief valve will then need to be opened to allow air to go in to replace the water going out. If you do not allow air to go into the tank it will air lock and no water will flow out.
When the tank is empty you can then start the cleaning process. To do this you will need to open the cold water valve full on for a half minute or so. Then let the water and sediment drain out. Reopen the cold valve again and then drain. Repeat this process until you get clean clear water when you drain the water. Then you know that the tank is clean.
If the drain valve gets plugged when empting the water, you may need to use a wire to unplug it or even replace the drain valve.
The relief valve will often leak after opening it to allow the air in. It is best to replace it to be sure you will not have a leak.
Be careful of the hot water as you initially drain the tank.
Refill the tank and open a hot faucet to release all the air from the tank as you fill it.
When you get water out of the hot faucet again, you can restart you heater by lighting the burner or reapplying power to the heater.
You now have a nice clean hot water heater again!!
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
http://www.fixya.com/support/r4422595-electric_water_heater_wiring_diagram
http://www.fixya.com/support/r4656190-electric_hot_water_heater_temperature
http://www.fixya.com/support/r4656414-replace_thermostat_element_electric_hot
on Feb 03, 2010 | Heating & Cooling
Noise in the water heater valve. How do I fix it?
Valve is not identified.
Cold water shut-off valve, TP valve, check valve, mixing valve, drain valve are the usual suspects associated with electric water heater.
Gas water heater has additional valves: gas shut off valve and gas control valve thermostat.
Check valve, TP valve and mixing valve probably need replacement.
If drain valve is leaking, put garden hose cap over end.
Shut off valve probably has a bit of blockage, or is not completely open. Try closing and then opening shut-off valve all the way, and if problem persists, replace or clean out valve.
What kind of noise? Are you sure the noise is from a valve or is it inside the tank caused by sediment build-up inside of tank?
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/How-to-replace-TP-valve.html
http://waterheatertimer.org/images/Water-heater-with-mixing-valve-300.jpg
Jul 04, 2011 | RTO Bradford White M-1-20U6SS 19 Gallon...
Dishes not coming clean
Check water inlet valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
How to test a dishwasher water inlet valve.
How to replace a dishwasher water inlet valve.
May 26, 2011 | Maytag Dishwashers
When starting the washer the water that fills the machine comes out with very little water
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Mar 20, 2011 | Amana Washing Machines
Water coming in stops short of the proper level - not enough water comming in to clean properly. I have to add water.
most dishwashers fill level is determined by time.
If the water pressure is to low, or the flow is restricted by sand or rust cloging the water valve, the unit will not fill with enough water to clean the dishes.
if you are willing to try, and you can use basic hand tools, you might be able to clean a clogged water valve.
first make sure the ELECTRICAL POWER to the unit is up-plugged or turned off. turn off water supply.
Valve is located under unit most can be reached by removing panel on lower front of unit. disconnect water pipe at valve and look for a filter screen inside the valve, remove it, clean it, reinstall it. now reconnect water pipe, and turn water and power back on look under unit and check for water leaks before reinstalling panel.
Sep 29, 2009 | Dishwashers
My Kenmore front loader will fill with 3 or 4 inches of water on it's own, when it is off and door is ajar??
Hi, possible your water intake valve are faulty, check back of machine where your( 2) intake water hoses are connected, shut water off, remove and clean water valve, it's possible you got high water pressure in you home (building) or your water valve maybe strain, or has a mechanical fault inside of it, you can remove back of machine, remove water solenoid valve, put valve apart and clean plunger, put valve together and see if same thing happened, if water still comes in after cleaning valve, you should replace it. before doing any repairs unplug machine, (disconnect power) good luck.
Aug 13, 2009 | Kenmore 44102 Front Load Washer
440 Aprilaire Humitifier small solinoid doesn't open
Make shure that the the filter in the bottom of the valve is clean. Turn water off use a 1/2 & 7/16 wrench to take apart the bottom connection on valve use a small screwdriver and push the small screen out and clean then put it back together.Use the same wrenches and take apart the top of valve clean inside valve and clean small orfice in plastic water line put back together. Make shure 24volts is gettin to valve you should her a click when furnace is running or fan. It may take a couple times to clean. Hope this helps
Jan 11, 2009 | Aprilaire 600 Humidifier
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Dishes not clean
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
29 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
