Question about Ryobi Garden
The trigger lock didn't work, i took the housing apart the springs came off both throttle trigger and lock. can you supply a diagram on where they connect? any help will be appreciated.
  • Richard Crate Apr 06, 2011
    Hello. Please provide the following information to FixYa so that we may be able to assist with your issue. What is it? Brand name, manufacturer, complete model number. Any other information you can provide will allow us to assist you better. Thank You.
SOURCE: poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Posted on Oct 27, 2008
evwood
  • 50 Answers
SOURCE: trigger jamming
I suspect that the cable to the carb is binding. Make sure when you reassemble the box, the cable works properly. Put the box together loosely and keep checking the action. Position the parts if it binds. Good luck!
Posted on Mar 28, 2009
slohry
  • 87 Answers
SOURCE: husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Posted on Apr 10, 2009
  • 124 Answers
SOURCE: Ryoby weedeater throttle housing. Replacing the throttle spring
From the limited information you have given I think your throttle wire is binding. It could just need lubricating or the throttle shaft or butterfly in the carburetor could be binding. Disconnect the throttle wire from the carburetor and see if the throttle wire is moving freely and check the throttle shaft in the carburetor to make sure it is moving freely. If both are free, then check to see if something is pinching or binding on the throttle cable.
Posted on Sep 14, 2009
  • 89 Answers
SOURCE: Throttle linkange spring connection
goe to briggs and stratton .com and put your model type and code it will bring up your diagram and that will help.
Posted on Nov 05, 2009
I have no throttle control.
The spring will probably be intended to return the throttle to the idle position when the trigger is released. There should be drilled holes or notched tabs that the spring will connect to. When the trigger is in the idle position, the connecting points should be just a bit farther apart than the length of the spring.
Jan 01, 2016 | Garden
I am trying to put a throttle trigger on my weed eater it's a stihl fs55c I can't figure out where the spring goes its been broke awhile I took it apart but I can't remember how it goes I...
with the trimmer engine to your left and the shaft to your right the trigger spring goes on the peg that holds it in the body like an L. It is going to be difficult to explain exactly how to do it and the pics I get from my phone are way to large to post here even after changing the resolution
Mar 30, 2013 | Garden
Brand new Huskie 450e used for two days and the throttle is now broken. The actual trigger itself feels like it isn't attached to anything anymore. Is it an easy fix?
In the 400 series of Huskies I have fixed, the handle comes apart with several screws. Sounds like the simple problem might be in the handle/trigger assembly. The more complex problem is if the throttle linkage rod popped out of the throttle. The outside trigger interacts with a black plastic insert and spring that provides pressure outward to keep the throttle low. This assembly connects to a thin metal rod that looks like the path a drunk would take doing a sobriety test after too many martinis. The rod goes into the housing and connects into a hole in the throttle assembly, then is locked in place with a plastic piece that slides down to keep the rod from falling out. In order to see this area, the cover needs to come off. I'll be honest. The last one I had, the rod fell out of both ends. It took me two days of pondering, playing around, cursing, getting up and walking away, then coming back to finally figure out where the ends went. The blue plastic piece had slid down, covering the hole, so I was at a loss as to where it attached to the throttle. NOTE: When removing the handle, try real hard to keep it together until all screws are removed. THEN VERY CAREFULLY begin to take it apart, looking in from the top of the handle. You might get one good glimpse of how the parts fit together before they fall apart on you. Husky does have a good website for exploded view diagrams, but sometimes they leave a little to be desired for 2-Dimensional art vs. 3-D Reality. Good luck.
Sep 13, 2011 | Husqvarna 450 e-series 18" Chain Saw
My throttle continues to stick. The motor races and it sounds like the engine is about to explode because of its speed. I opened up the handle and the spring seems out of place. When I squeeze the trigger...
You should see some small wear marks inside the handle where the spring is supposed to rest. Also, check the throttle cable where it exits the plastic engine housing and goes to the throttle plate on the carburetor. Make sure it is connected correctly and not binding on anything on the way to the carburetor. There really aren't any diagrams or pictures available on the net of the insides of a Ryobi weed-trimmer's throttle trigger and spring.
When you squeeze the trigger the steel cable should move, the cable housing should NOT. If you look closely, you will maybe see how it works and all goes together. It is not that complicated.
May 21, 2011 | Ryobi Garden
Took throttle assembly off of my 2005 sportser. spring came off and i can't figure out how it goes back together.
The only spring that I know of that is at the throttle assembly on the handlebar is a tension spring that goes on the throttle lock tensioning device on the bottom of the throttle housing. It the thumb screw on the bottom of the throttle that you can turn to lock the throttle in a particular location or put a resistance on the throttle. It holds enough tension on the screw to keep it from turning and falling out.
Good Luck
Steve
Apr 03, 2011 | Harley Davidson XLH Sportster 883...
How do I replace the trigger on the Huskie 350? Does it just snap out, is there a pin to drive out or do I have to separate the case. If I have to separate the case, how?
To remove the the trigger there is a alloy pin that needs be be driven out. Before you can take the trigger out, you need to remove the trigger lock ( dead man ) to remove the trigger lock, gently pry the two halfs of the tank apart at the rear opening where the lock sits, this will allow the back end of the throttle lock to pop up, once up pull the throttle lock toward the rear of the saw and it will come away ( bayonet fitting in the tank ) the trigger will now come out with its spring once the pin is removed.
Feb 12, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Friend took my 900420 nailer apart to clean it and when he got done, had a small spring about 3/16" x 1" left over. Does anyone have a clue where it might go?
Thin spring?
Goes in-between the Follower Guide and Button.
There are several Coil springs used in a Paslode 900420 framing nailer.
1.In-between the Upper Probe and the Lower Probe.
(Safety device you depress so the gun will shoot)
2.Trigger
3.Lockout Bar
4.Follower Guide and Button
(There is a flat spring also. Goes in-between the Probe Stop and Probe Release)
Here let me show you,
http://www.paslode.com/uploadedFiles/Cordless_Framing_Nailer_Parts_Diagram_Schematics.pdf
Oct 17, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Crafstman chainsaw at full power when started
If you had this apart, a few things may have happened. First the linkage from carb to throttle trigger maybe jammed between plastic housing or linkage may have come apart and throttle is in the full open position. You'll have to take this apart again and follow the linkage between carb and throttle trigger to ensure all is connected and moving freely and properly. Use care when putting housing back together.
May 10, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
