Question about Panasonic Car Audio & Video
1992 Mazda Miata AM/FM/Cassette Radio has sound from the left speaker only. The radio may also cut off unexpectly, but will come back on if I fiddle with the volume or balance controls. The radio also will not come on in damp weather. I suspect the volume and balance controls need to be deoxidized, but I've already tried with small success. I may need to be more aggressive with thorough degreasing before trying Deoxit, but I don't know which products to use. On the other hand, I may be on the wrong track.
  • 51 Answers
SOURCE: How to adjust balance on Panasonic SA-EN37 radio-cd-mp3player
The manual can be downloaded here:
Panasonic RXD27 Manual English
Cheers
Critter
Posted on Jan 07, 2009
etirbynnor
  • 655 Answers
SOURCE: Is there a balance control on this radio or is that fixed???
Hello kayriecken,
You did not specify whether you have the old classic Becker or the new retro. I'm pretty sure that the knobs were "spring loaded" on my old '60's Becker (actually in a 1971 Mercedes 280S - later replaced with a Blaupunkt). On mine, you just pulled out lightly on the knob and it switched function to balance. One side, the volume controlled left to right balance, and the other side, tuning, controlled front to rear balance (fader). Try it and see if it works.
Hope this helps.
Posted on May 05, 2009
  • 67 Answers
SOURCE: Aux in runs only back speakers and no volume control
check sub setting some radios can select between non fading sub output or aux input
Posted on May 08, 2009
darjr
  • 378 Answers
SOURCE: The unis a Clarion AM
try to press back the # 1 button, M1 means that memory 1 or press #2 if still no improvement. I assume that one the button is stuck ( continuously pressing). you can check it by pressing all button one by one, good switch or button will sound click every time you press you can hear it by moving your ear near to the switches. If there is jam switch or bad sw. you can't hear this click sound. Once you identified the problem simply change the defective sw.
Posted on Jun 04, 2009
ironcrossaud
  • 281 Answers
SOURCE: 2002 harley davidson am-fm cassette radio
check out www.radiosound.com
Posted on Sep 04, 2009
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
Jan 31, 2017 | Cars & Trucks
Radio trouble shooting
It seem like the stereo for the radio is failing, either because of a weak radio signal or defective aerial
Jul 30, 2014 | Mercedes-Benz 1992 Mercedes 500SL Radio /...
Lexus radio sound crackles then cuts out altogether
in radio mode, A./m and F/m
and what about other modes. Cassette, CDDA disc? all crackle
if only radio, then connect a test antenna to the radio
solved?>
if not the radio is bad, or DC power to the radio is bad.
cuts out, does that mean, just the sound dies in all modes. (left and right speakers)
or the sound and even the dial lights and station tune data is dead too.
cuts means nothing with out specifics.
Jun 14, 2014 | 1994 Lexus LS 400
I need to find the diagram for the wires of the car stero AM/FM Cassette 1999 Ford Ranger XLT
1999 Ford Ranger Pickup Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger N/A
Car Radio Amp Trigger Wire: Blue
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
pls rate
Aug 17, 2010 | Buck Ford Econline Van 1998-2006 Stereo...
I have a 2001 Dodge Ram 1500 that I'm trying to up grade my radio form a A and fm cassette to a dual CD cassette . I need help with wiring because they are different colors.I have the new 16 pin harness...
2001 Dodge Ram 1500 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Sep 09, 2009 | Durabrand Car CD Player and AM/FM...
Radio code miata locked
try either 1414 or 0532. on my mx5 2003 UK its 1414
Apr 12, 2009 | 1996 Mazda MX-5 Miata
Sound
if your tv has a headphone jack and your truck has a cassette player, they make an adapter in the shape of a cassette with a wire running out of it and a small jack that will hook into the tv and you should get sound out of your truck stereo. if no cassette player, then they also make an fm transmitter that will hook into the tv and then you tune your fm radio to the frequncy required. radio shack or some place like it usually carries things like this.
Apr 05, 2008 | Sansui COM311AD 13 in. Combo
Fm radio/speakers
check that there are speakers! stupid as it sounds, sometimes there are just covers with holes behind...
If there are speakers trace the wiring through to the source make sure it has been conected both ends...
Or check the balance & fader on the set.
Dec 19, 2007 | Radio Communications
Car Audio & Video Logo
64 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
