Question about Porter Cable 9748 Tiger Saw Kit
I have a porter cable tiger saw model number 735 and my blades will not lock into place. i can put the blade in and it will not lock into place as i am cutting something the blade pops out... and was wondering what could i do to get it fixed, or let me know what the reason is behind it of not locking in....
3 Suggested Answers
SOURCE: Blade won't lock.
There is a ball lock in it and you have to twist the ball lock but if the ball lock is frozen generally WD40 will help unfreeze it and work it until the ball is free and should work just fine.
Posted on Jul 22, 2009
  • 142 Answers
SOURCE: Porter Cable Tiger saw 9735 stopped working
blow it out and spin the motor by hand you may have saw dust blocking the brushes. If that's not it check the brushes to see if they have life left in them. If not that check the cord for an open with a volt ohme meter.
Hope that helps!
Posted on Feb 28, 2012
How do u put on a saw blade for a cordless circular saw.???
First remove the battery, next make sure of the blade rotation and remove the hex bolt and OUTER flange lift the guard and put the blade on the spindle. Reinstall the outer flange and tighten the hex bolt, generally newer saws have a spindle lock to hold spindle to tighten the blade. If this is a Porter Cable like in the header you can go to dewaltservicenet.com and with your model and type number find an operators manual. Let me know if you need more assistance.
Mar 11, 2012 | Porter Cable Saws
Hope that helps!
Jan 24, 2012 | Porter Cable VariableSpeed QuikChange...
Cannot get the blade out of the porter cable reciprocating saw
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
May 27, 2010 | Porter Cable Variable Speed Quik Change...
Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Dec 07, 2009 | Porter Cable Variable Speed All-Purpose...
How do I replace the blade?
Hi rq,
Look at the base of the blade, there is either a half twist quick disconnect or an allen screw.
Safety first: Unplug the saw.
If its the allen screw it will be located to one side of the blade. Just loosen it , pull the blade out.
The half twist ring doesa what its name implies. Twist it as far as you can (holding the saw with the bladed to the ground allows it to drop out) to free the blade.
Best reqards
Mike
Sep 11, 2009 | Porter Cable Variable Speed All-Purpose...
How to remove the blade on a tiger saw quick-change,model#737?
At the base of the blade where it attaches in the saw you will see a round in shape with ridges fixture. Turn it so the slot is in line with the blade. Then you will be able to remove the blade. If the fixture does not turn, move the blade up and down while you turn the fixture.
Jun 19, 2009 | Porter Cable Variable Speed All-Purpose...
Blade won't lock.
Jun 09, 2009 | Saws
Broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
Porter Cable 9748 Tiger Saw Kit Logo
106 people viewed this question
Top Porter Cable Saws Experts
Dave
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
