Question about Dynex DX-LCD32-09 LCD TV
I'm looking for a backlight inverter VIT68001.95 for my DYNEX DX-LCD32-09. I've found many different backlight for this model. Does it have to be the VIT68001.95 which is currently in it or can I use a different one and what's the difference?
  • 108 Answers
SOURCE: dynex-42" plasma, DX-PD42-09, Directcode TV, Need renote code
try some lg codes
Posted on Jan 08, 2009
rulds2008
  • 3866 Answers
SOURCE: Broke a brand new TV screen dynex dx lcd32 09 Does anyone know how to buy a replacement screen
Try ebay look up the model number on there useing advanced search you just might find one.. Good luck.
Posted on Apr 22, 2009
  • 2318 Answers
SOURCE: Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
Posted on Sep 28, 2009
SOURCE: i got a dx-lcd32-09 and just the screen went of
question : i can have a picture when playing dvd to tv but only has sound for tv but wont let me get to channel of of the menu ?
Posted on May 15, 2010
hmerchant110
  • 7191 Answers
SOURCE: need owners manual for dynex dx-l19-10a
You can download the owner's manual by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Posted on Jun 04, 2010
I have a dynex tv model dx-l40-10a i have no picture on the sceen i test with a flahslight and i see the menu on the sceen i dont see the backlight because is no vent hole on the back of the tv
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 21, 2017 | Dynex Televison & Video
White screen, can only see shadows of the picture
Hello
Its backlight is not working. Check the CCFL tubes, and it backlight inverter board for fault.
Backlight inverter board will look somewhat like this. If this board has damaged, CCFL lamps won't light up, and there will be no backlight. OK.
Jan 03, 2012 | Dynex DX-40L260A12
What is the price for Model no AX-37D 2V Daenyx LCD
POWER BOARD = $54.99 "http://cgi.ebay.com/Dynex-DX-LCD37-09-Sub-Power-Supply-Board-BA71F0F01026-1-/160540235334?pt=LH_DefaultDomain_0&hash=item2560f19646"
INVERTER =
$89.95 http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1183673&Click=54985"
THE SCREEN
http://cgi.ebay.com/Dynex-DX-LCD37-09-Screen-only-/330543674141?pt=LH_DefaultDomain_0&hash=item4cf5f0331d
which cost
US $169.00 Buy It Now(will expire in 8 days)
Apr 09, 2011 | Dynex DX-LCD37 TV
My dynex tv has sound but no picture it happened a day ago i found that the problem might be the backlight inverter board if so how can i fix it
Test: You might see a pic by shining a bright light against the screen. (Halogen can burn a spot if too close for too long like 15 seconds). If so, you probably have an inverter, backlight tube or coil/driver board problem. Some of these units have a bad ground on the tube driver coil board which can be shimmed and/or tightened. Sometimes a simple car light tester (continuity tester with a 12v bulb) from casing/mount ground to any of the - side of the backlight driver coils will light the screen and reveal if and which tube is non functional. I leave one dome light running in such ground position one of my TVs at all times for regulation and night dimming.
Jan 27, 2011 | Dynex DX-LCD32-09 LCD TV
T.v.powers up, sound but no pic. t.v. is only 3 months old.
Tv have a dead long board call the LCD inverter board.This long LCD inverter board,help to get a backlight to the LCD screen panel,to produced a picture.Tv only 3 months old,take ur warrenty repair,call the Dynex corp. for warrenty repair.
Oct 16, 2010 | Dynex DX-L22-10A 22 in. LCD TV
Dynex dx-l40-10a flat-screen hdtv turns on and the screen is viewable for a second then goes black. And power light is still on
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight. With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing
I hope this helps.
Jul 21, 2010 | Dynex DX-L42-10A 42 in. LCD TV
Dynnex lcd37 tv display problem ?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Dynex+DX-LCD37+
Please post back what you find.
Dec 23, 2009 | Dynex DX-LCD37 TV
No picture when I turn the tv on but have sound. If I turn the TV off and on again I get the picture.
It can be that the backlight inverter board is going out or the power supply that supply the power to the inverter board is going out due to bad filter capacitors.
Oct 31, 2009 | Dynex DX-LCD37 TV
Dynex dx-pdvd9 backlight died
Unfortunately these small electronics are so proprietary, a replacement backlight would have to be one specially made by Dynex. Dynex probably won't sell you a new backlight, they'll just sell you a whole new unit. It'd probably be cheaper that way too.
But you can try. You can talk directly with them using this website:
http://www.dynexproducts.com/pc-519-22-dynex-9-169-widescreen-portable-dvd-player.aspx
And ask them how much a replacement backlight would cost.
Dec 13, 2008 | Dynex DX-PDVD9 Player
Dynex DX-LCD32-09 LCD TV Logo
171 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
