Question about HP LaserJet 5550 Printer
Printers error code on hp 5550 13.20 jam their is no paper inside machine
  • 1 more comment
  • jameslm58 Nov 14, 2008
    We were getting a 59.30 error so we replaced the fuser and the imaging kit but we are now getting 13.20 paper Jam error with now paper in the printer.
  • samir alsharee3 Dec 13, 2008
    I have an hp LJ 55500, I keep getting this message "standard output full, remove paper from bin". I tried everything with no results to this problem. Pls. help.
  • alihussain_1 Mar 20, 2010
    we did not find any problem after removing the plate plz tell us how to solve the error of sandard output full
  • 138 Answers
Your problem is going to be in the paper feed assembly. Remove the cartridges and look for a plate under the bottom cartridge. Remove the plate and I believe you'll find your problem. It's a pretty common place for hidden jams on the 5500/5550 printer.
If you still can't find it hit my user name and let me know you need more help so I can give you more assistance.
Hope that helps you.
Posted on Sep 06, 2008
How to clear paper jam in hp photosmart C270 printer
There does not appear to be a Model C270 in the hp photosmart printer models. Do you mean it displayed a "C270 error code" in what Model No. Printer? The error code C270 indicates a paper jam/misfeed error.You possibly have paper remnants still inside Machine. You could remove drawers from machine, and look inside for remnants of paper. Maybe try turning machine off and on using red switch at knee level. If there is truly nothing blocking a jam sensor, then problem is likely a bad sensor. 99% of the time HP does not make replacement parts available to out-of-warranty printers. That's why I had to dump my C5550 HP Photosmart All-in-one printer; my office machine repair business could not get the replacement sensor! Remember: "Brother model" offer free toll-free phone tech service for the LIFE OF THE PRINTER! That's why I bought a Brother this time!
Jun 17, 2014 | HP Officejet Pro L7680 All-In-One Printer
How to clear error code 13.20.00 on CP3525dn
Error 13.20 indicating paper jammed.> check any paper jammed inside? remove it...observe the diagram of paper path & sensors where possibilities for paper jamming..
Oct 24, 2011 | HP CP3525DN Color LaserJet Printer
Says paper jam, worked fine yesterday but there is no paper even in the machine...
Those errors that deal with paper jams. An error code "6A80" can either represent a sheet feeder error or a debugging unit. This means that there may be scattered bits of paper or other debris trapped inside the unit itself. The potential for this error is high; when the paper is removed from a jammed feeder, bits are prone to fall off and cause this error code. The user must inspect the inside of the printer thoroughly. This error can result from problems with the unit serving or the electronic card; however, the most likely cause is debris caught inside the printer interfering with the printer's operation.
Nov 09, 2010 | Canon PIXMA MX340 Wireless Office...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
It says paper jam, but there is no jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 17, 2009 | HP 1010 Plain Paper Inkjet Fax
HP 4200 printer paper jam. No paper is jammed
OK, if the printer says jam but no paper inside and prints after you open and close the cover the paper likely never made it out of the tray. Or the machine thinks the page never made it out of the machine.
As far as input check your rollers 1 in the tray and the pick up roller in the machine if you don't have alot of pages on the machine these likely OK.
Next (and this I have found often) check the paper back stop in the tray. This is the guide to set the length of paper. If it is set just a little long the roller cannot catch the edge of the paper. Sometimes the teeth the guide sets in are broken or worn.
The output would be the sensor in the fuser replace fuser.
Hope this helps
Feb 19, 2009 | HP LaserJet 4200 Printer
Hp 2355 all in one error message
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP 2360 Paper Jam
pls look the swich for paper inside, maybe the switch did not tuns back to his position
Oct 15, 2008 | HP Deskjet 2360 InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP LaserJet 5550 Printer Logo
515 people viewed this question
Seeker5211
Seeker5211
