Question about Sharp Microwave Ovens
I have a sharp Convection oven - model R995E. THe seal on the inside appears to have melted in one place. Can you advse if this is replacable
  • Sharp Master
  • 9,086 Answers
Unless it's old, most parts are available for Sharp models.
To order parts, visit this page, click on Support, then on the next page, select Spareparts Outlets under Frequented Resources.
(I would give you a direct link, but since the site uses frames, it's better this way!)
Posted on Aug 08, 2008
What fuse for sharp R995e
Howdy Hylton,
I could NOT get your model number (R995e) to double check...
Part... plus video... (maybe)
Very best thing to do...
is a search on YOUR ACTUAL PART NUMBER (s)...!!
http://www.repairclinic.com/PartDetail/Sharp-Line-Fuse/14QBP20CSB/757868?ss=b113-x723939356520636572616d6963&mr=0
You will HAVE TO VERIFY this number yourself.
Sharp Line Fuse 14QBP20CSB
Sears has an excellent reference library... but if you want the same part you can get everywhere else for the HIGHEST price
SEARs ($$$$) is (not) your place... get your real part number
(3 estimates... always!).
- Don't forget to get that other SPARE FUSE...!
(Likely your HIGH VOLTAGE... magnetron is likely history)
Happy hunting.
appliancepartspros...
Search Over 2 1 Million Appliance Parts
- repairclinic.com
- ezapplianceparts.com
- partssellect.com
http://partssellect.com/ http://ezapplianceparts.com/ Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Mar 31, 2016 | Sharp Microwave Ovens
I need a cooking manual for a Sharp Convection Microwave model R820BW
If you go to the Sharp web site and download the manual, or part you want, there are a few recipes in there, and it looks like they have an offer for a convection cookbook inside the manual.
Mar 16, 2014 | Sharp R-7A85 Microwave Oven
I have a Sharp Carousel Convection Oven. The inside glass shattered. Still in place but all crinkled. Can I get it replaced?
yes,if it is the glass plate that turns that you are referring to,most plates fit most models,just keep the original plastic ring it rides on
Dec 04, 2010 | Microwave Ovens
Sharp R-930 Microwave/convection turntable support burned
We have the service manual for this model and have uploaded it for you here.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 15, 2010 | Sharp Microwave Ovens
I have a sharp microwave-convection model #r-7a85. how many watts this oven needs or have thank you
800 or 1000 are standard wattages. It should say on the plate on the inside 'doorway' of your oven - that is where I find that info on my sharp microwave. It could be on the back but, like I say, normally inside the 'doorway' to the oven
Dec 27, 2009 | Sharp R-7A85 Microwave Oven
Sharp 930 AK Convection/Microwave Oven
When you close the oven door the latches operate a couple of interlock switches that control power. It may be that one of the door switches is bad or out of adjustment. It's also possible that one of the door latches is broken so it's not hitting the switch. There should be two door latches. Are they both there? This oven could be fixed by adjusting or replacing the interlock parts as needed. Because of concerns about microwave leakage from an improper door seal, you should have this oven serviced by a professional.
May 21, 2009 | Sharp R-930AK Convection/Microwave Oven
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Dec 06, 2008 | Sharp R-1874 Convection/Microwave Oven
Sharp R-930 not heating up to temperature
It may be the thermistor, heating element, etc.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The manual has complete disassembly, test and part replacement info, as well as a very good troubleshooting chart.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Dec 05, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave Panasonic NN-A554W
This is usually caused by either exposed metal in the micro, or the metal in the bag of popcorn was overexposed. Typically if this happened, replacing the door components costs around 20-50 bucks. Which in, in any case, if the unit is over 2 years old or older, it would be more fesable to replace the unit.
Sep 17, 2007 | Kenmore 63672 Convection/Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
