Question about Honda Garden
I have a honda mini-tiller fg100, i beleave the clutch is out, ,cause when i've give it gas the blaid don't move. how dow i replace the clutch
  • Honda Master
  • 11,800 Answers
The clutch is centrifugal - 2 shoes are flown out when the revs go up. Here are the parts
http://www.planopower.com/store/honda/fg100.shtml
You just remove the command cables on the carburetor ant take out the 4 studs that secure the motor to the transmission to access the clutch pads - the drum is attached to the transmission shaft.
If you discover that it's the shaft that is broken here's the schematics for it
http://www.odref.com/homelite/tillers/ut-22082.pdf
Posted on Apr 06, 2011
Motor runs but the tines want turn
Either the clutch is gone or the transmission gear is stripped. These need to be properly greased annually so that this happens less. The transmission replacement can be done but the dealer will charge you about what you paid for it ($250) or if you know someone handy they can order the parts here: http://www.planopower.com/store/honda/fg100.shtml and rebuild it for you. It would cost about $85 for a full transmission rebuild.
Good luck.
BW
Jun 19, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda FG100 tiller will not prime, filter replaced
Well if the unit has fuel than it should prime unless the primer bulb is damaged and unable to force air/gas through the line. This is definetly a fuel issue, I would remove both the line from the tank to the carb and carb to engine and clean them thoroughly.
When you press the bulb the carb should shoot gas from the unit when disconnected. If this isn't happening your clog is here. If it does eject gasoline than your clog is the clear line which sometimes collects sediment if the gas is poluted.
Mar 18, 2010 | Honda 25cc 4-cycle Mini Tiller
How do you change the oil on a honda fg100
Lay the unit face forward so it is laying on the gas tank and the engine is level. Fill through the dip stick access until oil is up to the bottom lip of the threading.
Mar 12, 2010 | Honda 25cc 4-cycle Mini Tiller
What type fuel; and mixture for honda fg 100 mini tiller
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
Mar 08, 2010 | Honda 25cc 4-cycle Mini Tiller
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Garden Logo
472 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
