Question about Lands Phones
HI, have a att&t 2.4 ghz cordless phone/answering system e2555 1. No outgoing dialtone 2 Phone rings, answering unit starts,cuts off phone rings three more then quits. Changed batteries in handset. no help.
  • 19,396 Answers
Hi.
First test line using a different phone (even corded one). If you have a spare phone cable test it. If there is a broadband filter installed, remove it. If possible test the number on a different line and wall-socket.
The only maintenance that you can do at user level is replacing phone cable and power resetting and re-sync the system. If that does not work, then the handset or relative cradle is faulty. In that case you need to call the phone manufacturer at the number listed on manual. This phones are not repaired on-site.
Try using the procedure below to reset the phone:
  • Disconnect all power adapter cables from wall sockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handset (or handsets) to cradle. I wrote at plural because the phone system may have more than one cradle/handset.
If that does not work, then the phone is defective.In that case you will need to replace/repair the faulty unit or the whole system.
Try first doing the reset suggested.
Regards.
Ginko.
Posted on Apr 06, 2011
Hi There my uniden 5.8GHz Digital rings only twice before answer machine starts how do i extent the time of ringing? thanks
For the TRU9380, you can set the number of rings for the answering system from the handset. Press Menu/Clear and select Answ Setup. Then choose the Ring Time submenu. Move the cursor to select the number of rings (Toll Saver, 2, 4 or 6 Times). Press Select to save the setting; you will hear a confirmation tone. (Note: the answering machine must be on.) In Toll Saver, it picks up after 2 rings if you have new messages and after 4 rings, otherwise.
You can find the manual for most Uniden 5.8 GHz phones by looking up your model here: http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%205.8%20GHz%20Digital . Check here if you have a different model.
I hope this helps.
Feb 10, 2011 | Uniden Cordless Phone
Need to record Outgoing Message for Vtech 5.8 GHz
http://www.vtechphones.com/vtechui/support/manual_list.cfm
Jul 03, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
Can't listen to my voicmail
Click on a left side link of download manuels. ------------ 40000 series DS4122-4 ------------ 50000 series cs5121-4 ------------ i6785 English Not sure what series you have, but take a look at these manuels. found here :http://www.vtechphones.com/vtechui/support/manual_list.cfm#214 if not anyof these listed- there are many others to view and I know you'll find right instructions here!! Let me know if this helped.--Stevie ----------------------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID ------------------------------- 5.8 GHz digital Four Handset Cordless Phone System with Digital Answering System and Caller ID --------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID i6785 - Spanish 5.8 GHz Digital four handset telephone system with digital answering system english i6786 5.8 GHz digital four handset cordless phone system with caller ID and digital answering device i6786 - Spanish 5.8 GHz digital four handset cordless phone system with caller ID & digital answering system
Feb 14, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
I cannot answer the phone. I cannot make a call.
Thanks guys! All I did was unplug the main phone and plug it back in. All 4 of the handsets now work!
Jan 23, 2010 | Panasonic KX-TGA101S Cordless Handset
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
Same scenario, all phones say "connecting"
Yeah OK. A 5.+ Ghz transmormer via your head is then releyed to via MWatts to & back to you. How smart are you?
Jul 03, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
No dialtone on handsets, 3 beeps sound
Deregistered 4 handsets, on suggestion from FixYa, by pressing hangup & # sign.
Then reregistered to base.
May 08, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Need more rings before answering machine starts
some phones have switches on the base unit, sometimes on the back or bottom.  some phones you need to use the set up procedures to set this feature.
Mar 22, 2009 | Uniden DECT2060-2 1.9 GHz Twin 1-Line...
Lands Phones Logo
29 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
