Question about Kenmore Dryers
Dryer is tumbling but there is no heat. Air flow is good. Is there something else besides the element that I should be checking.
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Apr 05, 2011
Dryer not heating
Hello Krazy
If your dryer tumbles, but there is no heat. You need to check this following:
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Best Regards
Neciforo Llanto
Sep 30, 2013 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
Whirlpool Tumble dryer low heat, taking three cycles to dry one load
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Jun 21, 2012 | Whirlpool Dryers
Zanussi TC7102W drying problems
not likely the timer but it does control the heat circuit. suspect the fan-air flow is being blocked and the elements are cycling on a safety thermostat instead of the operating thermostat. check for blocked or restricted vent and plenty of air coming out the vent when running. check for a flapper on the vent not opening or only open part way.
Mar 01, 2012 | Zanussi Dryers
My dryer does not heat up? how do you check the heating element? Model #DE27T3WXFB
Hello there and thank you for choosing fixya
Please Closly check the following
Dryer tumbles, but there is no heat
Dryer takes too long
  • Check the lint trap
  • Check for proper air flow
  • Inspect the vent hose for kinks or dips
  • Test the heating element
  • Test the thermostats
Jun 29, 2011 | Dryers
LG DLG2532 dryer not heating up, lint trap clean, good air flow out exhasut vent, all controls seam to be working i.e. lights on buttons and chimes good, seams like its not getting gas but valve is turned...
Hi, Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 16, 2010 | LG DLE2532W Electric Dryer
My Whirlpool dryer has stopped heating-still seems like air flow and tumble is good. Recently replaced computer. Dryer is only 5yrs old.
if your heating element is good then you need to check the thermal fuses in the cabinet if one of those is bad then it needs to be replaced.all thermal fuse should have continuity as well as the element if one of them does not have any continuity then replace it
Mar 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
I have an old Kenmore dryer, but I don't know the model. The dryer tumbles, but does not heat. I checked the gas line and it's turned on, and I'm not too sure how to check the air flow or the heating...
put your hand where the exhaust comes out of the building you should have a very good air flow from there
no matter what model it would be the same ignitor
without the model num i caNT REALLY HELP YOU GET INSIDE
Oct 04, 2009 | Dryers
Warms up and tumbles, but will not dry the load
possible poor air flow out of the dryer and the house. check these and repost. It could also be a partially bad element. Post the model number as well.
Apr 13, 2009 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
