Question about Kenmore 54701 Dehumidifier
Dehumid. was working, went to empty it and now it acts like it has no power
  • Anonymous Apr 06, 2011
    Thank you but I have done this and made sure it was in correct, no luck. Anything else?
    Brigadier General:
  • 4,736 Answers
If you mean you emptied it, and replaced the holding tank and now it doesn't work ... The holding tank probably didn't activate the safety trigger. Remove the tank and reinstall it, making sure that the tank triggers the safety switch. That should solve the problem.
Posted on Apr 05, 2011
  • Rich Landrum Apr 06, 2011
    Wow, what I suggested is generally the problem 95% of the time. First, turn the Master On/Off Switch to OFF and unplug the unit. Then, check the receptacle that unit was plugged into, to make sure it's still active and the circuit breaker for it hasn't been tripped. If that checks out fine, leave the unit unplugged for 12 - 15 minutes and then plug it back in. Turn the Master On/Off Switch to ON and set the controls as you normally would. If the unit now operates as it should, that 12 -15 minute timeout, allowed it to reset itself and you're ready to go.
    Please keep me advised and don't forget to rate my responses to you. Thanks.
Bucket fills but unit will not stop dehumidifying.
probably a bad switch at the float assembly...check that out....probably going o have to replace that. check also for loose or disconnected wiring at the switch. let me know what happens
Oct 01, 2008 | Frigidaire FDL50R1 Dehumidifier
I stored two different comfort air dehumid. for about 6 months & strangely both now leak. They leak at the bottom opposite of were i have the drain hose attached to a draining garden hose. The hose...
Yes... set the dehumidifiers up on blacks so that the hose drains downward and your problem will be solved... make sure the hose is supported so that it steadyly slopes downward and does not trap...
The outlet is very crappy and the hose does not seal well ...also make sure the hose end has a washer in it...
heatman101
Aug 26, 2011 | Comfort-Aire BHD-301 Dehumidifier
My dehumid is model # DH404Ey6. I plug it in and it reads 70% on the front setting. The power on/off button does not work. Or, at least, it doesn't react when I push the button. I put the bucket...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 25, 2011 | Goldstar Dehumidifiers
Water not going into hose or bucket
where are u located and where aqre u using the unit
a dehumid wont work properly below 60 degrees
or 40 percent humidity
Oct 17, 2009 | Goldstar DH304 Dehumidifier
Do I need an attachment to connect hose to my new dehumidifier?
it should be generic. you just need a part with the same thread pattern. you could fix that a lot of different ways. as long as it screws in your ok. make sure you put some teflon tape on it to prevent it from dripping
Oct 06, 2009 | Kenmore 54501 Dehumidifier
Cycles every 3 minutes
It may be in a basement that is to cool. Unless this is a special low temp dehumid it needs to be in the upper 60's to work correctly. Also a 50 pint is for a pretty good size area, if it is in a small area or if the temp is to cool in the basement it is in it will freeze up and cycle off. 3 min is awfull quick though. It may be low on freon also. Just a couple things to think about.
Jun 20, 2009 | Whirlpool AD50USS Dehumidifier
Haier dehumid-HDN455-How do I clean?
that grill like area may be the dehum's coils. Yes they have to be cleaned. You use this dehum every day and so you have to clean it more often. See if you can with a small brush and a vacuum. clean it. Or if you have an air compressor you can blow it out.
Keeping the dehum clean will allow it to work better.
Feb 05, 2008 | Haier HDN455 Dehumidifier
Kenmore 54701 Dehumidifier Logo
79 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
