Question about GE Refrigerators
Water accumulates under the crisper drawers - GE Refrigerators
  • 96 Answers
You have a restricted condesate drain . You need to disassemble the rear of the freezer, defrost and clean condensate drain. Freezer probably got too cold and froze the condensate in the pan. Which means turning the thermostat to a warmer setting or recalibrating the thermastat internally to a warmer setting or replace thermostat to prevent from happenning again
Posted on Apr 05, 2011
  • 51 Answers
SOURCE: water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 13, 2009
  • 82 Answers
SOURCE: Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Posted on Jun 19, 2009
SOURCE: water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Posted on Jun 24, 2009
SOURCE: Water from freezer dripping into fridge freezing and accumulating
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Posted on Jul 01, 2009
  • 121 Answers
SOURCE: my no frost is leaking water from under the
You have a clogged drain tube in the freezer . here is how to repairit. take off the ice maker if it has one. then remove the 1/4 ince screws in the back. the whole back panel will come off.depending on the ice build up you might have to defrost the unit. if you would like to easily fix it just unplugg the unit and let it defrost. defrosting will unfreeze the line. this will sovle you problem for a while but it will happen again.
Posted on Oct 20, 2009
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Water accumulating in bottom of refrig under crisper drawers but not in drain pan under unit.cannot locate drain line
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Kenmore Refrigerators
Whirlpool refridg. accumulating water underneath the crisper drawers. I don't see where it is coming from. What is breaking down?
it is probably condensation from the shiny plastic drawers.i put a piece of kitchen roll under mine once a week...
Apr 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water is accumulating in the bottom of the refrigeratior below the crisper drawers
check and make sure the drain tube is not frozen over and is free and clear to allow the water to drain in the drain pan.
Mar 19, 2010 | Refrigerators
Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Sep 13, 2009 | Kenmore 71112 / 71114
Large amount of water collecting inside refrigerator
water drainage passage and pipe is blocked stop the refrigerator and clean the pipe
Sep 08, 2009 | Whirlpool Refrigerators
Unexplained water accumulation under the crisper/produce
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 10, 2009 | Whirlpool Refrigerators
Fridge problem
There is a drain, usually at the bottom of the refrigerator compartment. Pull out the bottom two drawers and see if there is a drain. It is usually in the very back of the inside compartment. Make sure it is not clogged. Usually, this is the problem.
Oct 18, 2008 | Frigidaire Refrigerators
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
