Question about Frigidaire Washing Machines
I have a frigidaire fron load washer model frfw3700lwd. it is on delay start and stays on there. I have tried leaving unplugged, tried to reset holding down the buttons for 10 seconds, and it will not get out of delay start mode.
  • 641 Answers
SOURCE: tripped my circuit and wont reset or start HELP!!!
Your circuit braker tripped because of a current problem that in your case caused a defective part. Since your machine is still under warranty, best way will be to contact to the appropriate factory service center for repair the problem. Good luck!
Posted on Aug 23, 2007
  • 264 Answers
SOURCE: Frigidaire Front Load Washer LTF530DS
if your door wont lock then its your door switch it had its day if you go down to your second hand shop they should help you it should cost about 15 pounds its a easy job and don't take any time to put in make sure you wright down the model number of the machine hope that helped you
Posted on Jan 05, 2008
SOURCE: Whirlpool Duet HT Washer
I guess electric door lock just stacked. To prevent door breakage call to your local appliance repair company.
Posted on Aug 04, 2008
  • 261 Answers
I have only worked on USA machines but I believe you have a control panel error.
Posted on Oct 15, 2008
  • 15935 Answers
SOURCE: washer is stuck on delay start
Unplug it for 40 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
How do I change f to c
Thank you for your post, Joel!
From the information you have provided you would like to change the temperature on your Frigidaire washer from Fahrenheit to Celsius. I was unable to locate any information regarding changing the temperature on your washer. If you need any further assistance please feel free to reconnect. -Matt
Mar 18, 2015 | Frigidaire FTF2140FS Front Load Washer 10...
My 8 hr delay button is stuck on help!
Good Morning Friend,
I understand that the 8 hour delay button is stuck on your Frigidaire washer, model# GLTF530DS. With the model number that you have provided, I do not show that there is an 8 hour delay button. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If further troubleshooting is needed, I ask that you please leave me the model number of your appliance. Typically this can be found either on the back of the door or around the edges where the door meets your washer. Hope this is helpful.
-Best Regards-
Jun 08, 2014 | Frigidaire GLTF530DS Front Load Washer
Frigidaire front load washer FTF2140 upon start it began filling and then turn off, did this everytime. Unplugged it and the same thing happened. Now the lights stopped coming on and it does not work.
Good Morning Heather,
I understand that your Frigidaire washer, model# FTF2140, begins to fill and then turns off. You unplugged it, trying to reset it, and now the lights are not coming on and your washer is not working. Since you have already reset your washer, by unplugging it, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your washer not working is. Hope this is helpful.
-Best Regards-
Apr 29, 2014 | Frigidaire FTF2140FS Front Load Washer 10...
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Accidentally hit delay start button and cannot get it to cancel. If this isn't free then OK....I do not have funds to pay for assistance. Your blurb on Bing says you offer free advice.
Try unplugging your washer for several minutes (at least 10 minutes) and then plug it back in. This will often reset the electrical (computer) board.
Oct 26, 2010 | Frigidaire GLTF2940E Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
The 8-hour delay will not reset
You can try this is you want. I can't promice you yhat it will work but it might be worth a try. Make sure the washer is on Press and hold the "SPIN SPEED" and the "SOIL LEVEL" buttons together, continue holding the buttons until a signal sounds then release them. This should reset your washer to the default factory settings.Hope it works for you. And you might also try unplugging it and see if it will reset it. GOOD LUCK !!
Feb 17, 2010 | Frigidaire FTF2140FS Front Load Washer /...
Just want to know how to reset a Frigidaire Front loading washer model FTF2140ES1
My 8 hour delay won't go off. Not sure how to get it to and the manual doesn't help at all. Can anyone advise? thanks.
Dec 31, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Washing machine won't start. when hit start 0' displayed
Hi, Unplug the unit from AC power for 30 seconds to 1 minute, This should reset it back to the defaults. Good Luck!
Feb 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Affinity LTF7000ES door not staying locked
unplug the washer and wait 5 minutes before plugging it in again!
this resets the system. If this does not work then you may have a faulty door lock, latch, or switch!
An need hands on service on location
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 31, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
100 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
