Question about Gigabyte GA-K8NXP-SLI Motherboard
Possible motherboard issue???
I have a suspected virus, but I am unable to boot from cd or go into safe mode. After the normal boot screens, a screen pops up notifying me that windows(xp) did not shut down correctly and it asks if I want to start normally or go back to a known good point. Here lies the problem. The keyboard does not work at all so I cant scroll up or down to chose the diffenrent options. The only way the keyboard works is when I am in the bios menu. So it just counts down from 30 seconds and then windows trys to boot (unseccusfuly) only to restart and repeat this viscious cycle. I am a novice when it comes to computer troubleshooting, please help!
  • hopeless2009 Aug 06, 2008
    Well, thanks for your help but like I said before, I am unable to boot from CD. The PC will not take commands from my keyboard when the "press any key to boot from cd" prompt comes up. (its not the keyboard bc I am able to go into the bios menu and navigate with it) Therefore, even tho I have the bios menu set to boot from cd, since I am unable to respond to the "press any key..." prompt, it will not boot from cd. It just goes back to the "sorry for the inconvience, but windows did not start correctly.." screen. Of course, on that screen it has some choices for me to make...start windows normally, boot from cd, boot from zip, and restart from last known good point..but I cant tab up or down to choose bc the keyboard is unresponsive in this menu also. Soooo, it counts down from 30 seconds and automatically trys to restart windows normally, only to repeat the process I just decribed above. DOH!
    test
    Habit-Forming:
  • 118 Answers
I suggest you should repair your OS. Just insert your winxp cd installer and boot from cd.
there is Rapir option at windows installer option. just repair it and you will get your windows work again in approx. 30 minutes :D
br
Posted on Aug 06, 2008
  • Gadget Corner
    Gadget Corner Aug 06, 2008
    You can try another boot cd like WINTERNALS or norton Systemwork bootable cd that can directly boot to cd contain without our confirmation.
    If this cd still dont let you enter any command from your keyboard, maybe you should try using USB keyboard and try to enter to windows cd installer again.
    br
SOURCE:
Asus Not loading windows
There can be a couple problems that can cause this, here are a just a few.
Safe Mode: Try booting to Safe Mode by pressing F5 when the computer starts up. Select SAFE MODE when prompted, and then hit ENTER. If you computer starts up it may be a driver related issue. Try un-installing the last driver you installed and remove that device. Restart Windows normally and see if they fixes the problem. If it does, simply check for a new driver for your devices that you had removed.
Some Virus can also cause booting issues. If you were able to get into Safe Modem try running your trusted virus program and Quarantine or remove any found virus(s).
Hard Disk Drive (HDD): Often HDDs are the cause for not starting up. They sometimes get knocked when they are running and that is very bad sometimes. It likes putting a scratch on a CD, it may or may not work afterwards.
RAM: Try re-seating the RAM. Simply remove them and reinstall them. You can find videos on YouTube on how to do this, just look for your model and search for "K53 disassembly" (but don't follow the video further than necessary!). If no change, try installing one stick of RAM at a time. (one, then swap the other, then both again).
Let me know your findings.
,Scorpio
Mar 06, 2014 | ASUS Computers & Internet
Getting late started and many virus
If your system will not boot up correctly and you suspect a virus is the problem, a recommended solution is to start your computer in safe mode and run a virus scan. By running your computer in safe mode, non-essential processes do not start and non-core components are disabled. In other words, only the minimum necessary programs will load. Tough to remove viruses, spyware and other malware usually have no chance to run and disrupt your system and can more easily be removed.
To run a virus scan in safe mode, you must have active anti virus software installed on your computer.
To run a virus scan in safe mode, follow these steps:
1.If your computer is on, shut it down
2.Power on your computer
3.Immediately after you power on your computer, repeatedly press the [F8] key (about once per second)
4.In the Windows Advanced Options Menu screen, use the arrows to select Safe Mode and presss [Enter]
5.Select your current operating system and press [Enter]
6.Select the user you would like to login under (if applicable)
7.When your system finishes booting, click the Start button on your task bar
8.Move your cursor over All Programs and navigate to your anti virus program
9.Click on your antiv virus program to run it and follow the anti virus program's normal steps to run a virus scan
10.After the virus scan is complete, Delete all detected viruses
11.Close out of your anti virus software
12.Restart your computer (it should start in normal mode)
Your Feedback is greatly appreacited.Thank you for using FIXYA.
Jun 30, 2011 | Computers & Internet
Unable 2 remove viruses and unable to uninstalling AVG Anti virus.
There is an AVG removal tool here.
I would suggest MalwareBytes to remove viruses.
Mar 01, 2011 | Computers & Internet
My laptop has a virus, and now every time I turn my computer on the screen is black. What should I do?
Try booting from Safe Mode and kill the virus by scanning.
If u r unable to login through safe mode, run the recovery cd and re-install the OS.
Oct 24, 2010 | Computers & Internet
Does not boot properly
Try running the diagnostics (Hold the Fn Key and press the power button or boot to the resource CD) See if the hard drive indicates and failure. If HDD fails, replace it. If it passes, then see if you can boot to safe mode (F8 at boot) and see if you can access windows there. If it does boot to safe mode, try MSCONFIG and edit the startup group and see if the system will boot normally in normal mode.
Other possible issues, fan failure causing overheating, or a clogged heat sink (Use compressed air to blow dust out of air intakes and exhaust) Virus and spyware
Sep 26, 2009 | Dell Latitude D810 Notebook
Whenever I turn on my laptop it goes to the screen that says safe mode, safe mode with networking etc... then when i click say start windows normaly it has blue screen that stays for 2 secs and then the...
Select safe mode !
If it finishes booting into safe mode then you can try another re-start.
If on the other hand it does not work after being in safe mode the issue may lie in some software you have recently installed or new hardware.
in either case remove that hardware or software (in safe mode) and try again.
If it still insists on re-booting when you select normal then I would begin looking at possible mal-ware, spy-ware or virus issues.
Should you get a specific error message then that may also be useful in troubleshooting issues.
If this information was useful please click
Aug 17, 2009 | Acer Aspire One PC Notebook
Windows XP not starting after power outage
I have just in fact a few days ago came across a similar issue. As to whether or not your hdd needs to be replaced is uncertain. What I can tell you is it seems as though the MBR or master boot record has become corrupt or one of the reader arms inside the hdd has failed.
Refering to the corrupted theory, may be simply fixed by booting off of a win xp cd and reformatting your drive and reinstalling windows after the format.
HOWEVER
In my case even booting off of a xp cd did not resolve the issue, every time anything would attempt to read from the hdd the computer would reboot. I suspected hdd failure at first, but this was not the case. It turns out it was a virus that infected the ntfs.sys and the MBR and put a binary code into those 2 files to reboot the machine.
Luckily at work (IT industry) I have a norton ghost server and was successfull at reimageing the hdd, doing so erases the MBR and everything else for that matter and rewrites it. However in doing so I lost all data that was on the hdd to begin with.
If you are not very tech savvy I would probably recommend hdd replacement however since you do have a HP which was prebuilt with xp, you don't have a xp install cd and thus unable to reload windows. I recommend finding a friend that has the xp install cd or you will have to go to the store and buy XP.
Nov 19, 2008 | ASUS P5PE-VM Motherboard
SCREEN RESOLUTION CHANGES IT SELF
check out for the latest update of display driver .
also refer to user manuals of your monitor/display adaptor/ motherboard { may be a compatablty issue with the os}
and make sure that your pc is free of viruses
Mar 06, 2008 | ViewSonic VA1703wb Monitor
Unable to boot up after windows xp
If you can get into the BIOS, try setting with default settings.
Dec 19, 2007 | MSI K8MM-V Motherboard
Unable to run Auto Installation Support CD, or Boot System
Is the new motherboard the same model with the one you have replaced. If so, there should have no problem on it. If it is different model, then you have to reconfigure the software installed such as the driver. your new motherboard surely has the CD included where the necessary software should be installed. But, the problem is that you cannot get to the WindowsXP screen..
Windows XP CD is also bootable.. Now in the bios setup there is a portion there that tells about on how to boot whether in drive a, hard disk or cd. Choose CD and inser the bootable Windows XP. In that way you should be able to get to the XP screen. Of course, you have to restart it to make the necessary changes but before that make sure you have saved the changes youve made to the bios setup.
Now if youre able to go to the main screen, uninstall software that are with your old motherboard and install the new one.
Hope to solve your problem.
Af
Dec 12, 2007 | EliteGroup ECS 761GX-M754(3.0A) Socket...
Gigabyte GA-K8NXP-SLI Motherboard Logo
83 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
