Question about Aurora Global AS702MX Shredder
Shredder runs continuesly in both Forward and Reverse and will not accept paper. Cannot shred credit cards either. I am searching for a schmatic to give me an idea how the unit works.
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
SOURCE: Fellowes P600C-2 Motor runs in reverse, but not forward
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Posted on Dec 07, 2007
SOURCE: Shredder suddenly runs only in reverse
I had the same thing happen to me today - I had just shredded a ton of stuff, emptied the bin 4 times - after emptying the bin the last time, all of a sudden it would only go in reverse. I pulled out my instruction manual and it says the motor might overheat and to let it cool down and try again. I let it cool down for about 1 hour, cleaned out the gears and dusted off the sensor and it started working even better than it did before.
Posted on Jan 30, 2008
fellowesrep
  • 102 Answers
SOURCE: Shredder won't shred any more.
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
You might have broken the actual mechanism enabling it to move forward. To be honest, your easiest solution would be to buy another shredder rather than attempt repair if this is the case, they're so cheap now.
Posted on Mar 27, 2008
Activa MD460 shredder misaligned?
they are not made to shred credit cards .
Jan 10, 2016 | Shredder Office Equipment & Supplies
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
My royal shredder js1100 will only shred in reverse.
Simple to solve!
Get some longnose pliers or strong tweezers.
Unplug the beast. You do not want to shred your finger nails, or your fingers.
Flip the mechanical part upside down. You will find small pieces of papers near the rollers. Pull them out with tweezers or pliers.
Keep hands out of harm\'s way, plug shredder and make it run in reverse for 1/10 of a second.
Unplug and remove more paper impacted in between rollers.
Repeat last two steps until no paper is seen by the rollers.
Plug and continue shredding your papers
Piece of advice. Do not shred your credit cards in shredder. Scissors are cheaper and do not mess your shredder!
Jan 15, 2014 | Office Equipment & Supplies
Only goes in reverse
Lube might not be necessary. Unplug the shredder from the outlet. Lift it off the shredded paper bin and turn it over. It is very possible that you have a jam. If this is the case, remove as much paper as you can making sure that you don't use anything that could do damage to the cutter'shredder blades. Once you have removed as much paper as possible, place the shredder back on the bin making sure that it is aligned properly. One way of making sure is to check for any space between the shredder and bin. If you do have space make sure that you replaced the shredder correctly on the bin; you may have to turn it around 180 degrees. When you get the shredder properly aligned, use the switch (DO NOT USE PAPER AT THIS TIME) to switch the shredder from Forward (shredding) to Reverse. You may have to do this a couple of times so be patient. At this point the shredder should be working in both directions. If so, move the switch to Auto or the center position and try a SINGLE sheet of paper. If it shreds that piece of paper, then you have fixed it. Be sure not to insert more paper than the shredder is rated for. Also, unless it specifically states that it can handle staples, credit cards, etc. do NOT let any of these items run through your shredder.
If none of the above works, buy a new one - :)
Jan 10, 2014 | Techko SH1524CP Shredder
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
Can't get shredder to work
Please ... unplug your shredder before doing this.
It sounds like you were on the right track picking paper out of the gears. The problem is that the paper can get really jammed up in there, especially when you use the reverse.
I found that I needed to use a combination of a small screwdriver with at least a 3 inch long blade to push the jammed paper through. The I use needle-nosed plyers to pull the paper through the other side.
Hope this helps. Please let me know if it does.
Blessings,
-- Wes (wcbyers)
May 02, 2008 | Tech Solution TS-4500 Shredder
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Mar 27, 2008 | Office Equipment & Supplies
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
Aurora Global AS702MX Shredder Logo
Top Aurora Global Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Aurora Global Office Equipment and Supply Expert? Answer questions, earn points and help others
