I have a nordyne E2EB-012HA. The thermostatic is turned off and the heater is running and will not stop until I turned the breaker off. What is wrong?
  • 43,501 Answers
Unhook the thermostat wires at the unit... if it stops then the wire or the t-stat is bad...
if it still runs then the contactor in the unit is bad...
heatman101
Posted on Apr 05, 2011
Will Honeywell digital thermostat work with Intertherm E2Eb 012HA
Probably, but it depends on the particular Honeywell thermostat that you have.
Oct 31, 2013 | Heating & Cooling
I have a intertherm e2eb-012ha. I need to know what size run cap to use. . The plastic coating has been melted so I can not see the run cap info.
It appears you may already have located your problem, the capacitors are very coming to burn out, if a motor will run after you spin by hand, mmore times than not the capacitor is the problem. The name tag on the equipment itself sometimes has the capacitor size and the motor nameplate usually does as well. you can call Nordyne support at 18004224328 and with your Intertherm Model number they can give you the correct capacitor size, which you can purchase at any HVAC supply house. If I had to guess, I would say you need a 5 mfd capacitor based on the blower size. but call them and verify. Also, most all supply houses that sell that capacitor can run the Intertherm numbers and see the correct size as well.
Jan 06, 2013 | Heating & Cooling
We have a Nordyne AC/Heater model # E2EB-012HA. My problem with the unit is that the heater will not turn off and the blower motor also won't turn off unless we switch the breaker to off. Also I...
my nordyne e2eb-012ha after running shuts off most of the time we have to reset the element breaker to get it going again. any ideas can"t find directions to how to get behind breakers thanks morris
Nov 28, 2012 | Heating & Cooling
Fan will not turn off
With your breaker on, the system selector switch (at your tstat HEAT/COOL/OFF) in OFF and the Fan Switch (ON/AUTO) in the AUTO position, Trace the wires from the Blower Motor to the blower relay. Try tapping gently on the relay using the plastic handle of your screwdriver/nutdriver. If the blower shuts off, the blower relay is sticking and needs replaced. Fortunately, this is a problem that will allow for the system to continue to control the temperature while you are awaiting your new part to arrive.
This is the problem for 90+% of the problem you are describing. If this does not resolve your problem, let us know and we'll look into another area.
Good Luck in your endeavor! :-)
Mar 02, 2010 | Heating & Cooling
Nordyne air cond Model E2eb-017HB got wet, shorted out
sounds like you experienced an ice over. this can destroy the compressor. if contactor is humming the call for cooling is present but the breaker poping is cause for concern. possibly needs new compressor.
Aug 23, 2009 | Heating & Cooling
Need help hooking the right colored prong wires onto my sequencer
There should be a wire diagram on the back side of the panel you took off to get to the sequencer
Nov 13, 2008 | Heating & Cooling
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
