Question about Logitech X-240 Computer Speakers
Cracking and poping - Logitech X-240 Computer Speakers
  • 93 Answers
Check all cable connections, make sure they're plugged in good and tight. If the noise happens when adjusting a volume knob, there is an aerosol spray sold at radio shack that will silence this problem. Otherwise, your speaker(s) may be blown.
Posted on Apr 05, 2011
Froze block on 02dodge diesel replaced 1freeze plug @oil cooler cover plate water still in oil . Was cooler busted?
sounds as if something else gave out when got frozen ,have to do a strip down an check for cracks etc
Mar 30, 2014 | 2002 Dodge Ram Pickup 3500
Hi hows it going well i have a 1997 honda civic.The problem was that the dipstick tube poped out and oil was leaking everywhere i was on the the road so wht i would do is just stop every couple of miles...
No, it is not repairable, it is blown, good and gone. What punched out the side of the engine block was an iron rod called a connecting rod, affixing the piston to the crankshaft. When it happens, it's a total loss for the engine, the whole bottom end is just scrap iron. The loud clanking was probably the end and pieces of the conn rod being thrown around by the turning crankshaft.
You will need to find another engine for it, if you want to keep the car. All from a dipstick tube, you have experienced a blown engine, also known as "throwing a rod", the usual consequence of oil starvation. A big loss, but you be wiser for it. Good luck.
Nov 07, 2013 | Cars & Trucks
Cracking and poping sounds
sounds like a loose conection try plugging into another outlet the pin?jack may need replaceing
Apr 05, 2011 | Logitech X-240 Computer Speakers
Back fires thru carb when excellerating but lopes when u take off manual trans
do you hear a pop pop poping under heavy acceleration or just one big back fireing when first accelerating? it could be an intake valve pop pop poping,and electrical,on the big bafireing under lite to med load. A cracked,or worn cap and rotor,weak coil wire,dirty carbruator,faulty accelerator pump in carb bad vacumn advance !slow ignition timing. BAD points and condenser if equiped on older model with carb.
Sep 01, 2010 | Jeep Cherokee Cars & Trucks
My computer speakers are popping and cracking.
Check connecting and Volume settings. Speakers might be blown. This happens when high volume is played and speaker tears causing a poping and crakling sound
Mar 24, 2010 | Altec Lansing Multimedia Computer Speakers
Loud poping and cracking sound
sounds like the high voltage problem from high voltage socket, check with an expert tech.
May 05, 2009 | Akai PT4298HD Rear Projection Television
Radio cracking/no sound
I disconnected the amp and ran jumper wires between the two harnesses basically creating an amp bypass everything now works fine.
Jul 14, 2008 | 2002 Chevrolet Monte Carlo
Toshiba 32cf650
hi there, there maybe a arcking of high-voltage form the FBT. or an amplifier section problem, do some test and check-up. ty
Jan 10, 2008 | Toshiba CF32H50 TV
Cracking and poping with Yamaha surround sound system
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
Burners Poping
Your ceramic burners have cracked, they will send you more but they too will crack after usage.
Feb 22, 2007 | Tec Sterling II Grill
Logitech X-240 Computer Speakers Logo
46 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
