Question about HP Office Equipment & Supplies
Could you please tell me how to release paper jammed in a hp photosmart c3175 ALL IN ONE printer scanner copier,if I pull the paper it just tears away. Thank You . RAY WINCH. EMAIL [email protected]
    Novelist:
  • 180 Answers
Clearing a paper jam from the rear door Follow the steps below to clear a paper jam through the rear door.
  1. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the unit. Figure 1: Removing the rear door could you please tell me - c00652942.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  3. Replace the rear door. Gently push the door forward until it snaps into place.
  4. Press Cancel to continue the current job.
Clearing a paper jam from the front door
  1. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door c00652943.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the unit, more paper jams are likely to occur.
  3. Close the print cartridge door. Figure 3: Closing the print cartridge door c00652944.gif
  4. Press Start Copy Black or Start Copy Color to continue the current job.
Posted on Aug 07, 2008
SOURCE:
HP photosmart C8180 all-in-one photo paper jammed in the photo tray and main tray, I use Fuji Premium 270g/m
you can pull out out the paper slowly after you tun off your printer, if it gets teared then try to pull out every piece of paper, you can give the print again. all the best.......
Dec 21, 2010 | HP Photosmart C3180 All-In-One InkJet...
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam: cannot reach the paper, how do I get
This video was created for the C7280, but works the same for your printer.
Jun 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6280 paper jam--won't print (of course), message reads 'add paper to main tray'
Please try this to clear the paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | HP Photosmart C6280 Printer
PAPER JAM WITH NO PAPER
This may be caused by a dirty sensor. Disconnect power supply, open the printer and clean everything. You may use toilet paper. Be careful not to leave fragments of toilet paper inside the printer.
May 05, 2009 | HP PhotoSmart C4180 All-in-One Color...
Paper jam in HP Photosmart C 6280
Have you tried removing the back panel. Click on the link for pictures but it is the easiest way to access the paper in the printer when jammed.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01257110&cc=us&lc=en&dlc=en&product=3194498
Jan 15, 2009 | HP Photosmart C6280 Printer
Paper jam
Open the rear access door to look for paper.
Dec 23, 2008 | HP Photosmart C6280 Printer
Paper jam
Try opening the rear of the printer. There should be a pull out plastic piece you can remove to clear paper jams. When you can get to the paper, don't pull too fast or you might tear the paper and leave some inside that will be even harder to remove.
Dec 10, 2008 | HP Photosmart C7180 All-In-One InkJet...
Cut off printer during print, paper jam tray 2 won't release
Open the cartridge door and remove cartridge...can you see the paper here...if so slowly apply even pressure to both sides of paper and pull...
keep me posted
Cheers!
Nov 13, 2008 | HP LaserJet 2840 All-In-One Printer
Open Questions:
257 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
