Question about Husqvarna 28cc Gas Line Trimmer
After 10-15 mins my 323l trimmer bogs down and won't keep running until it cools off?
  • Husqvarna Master
  • 1,807 Answers
Check the fuel tank vent, it could be creating a vaccum in the tank
Posted on Aug 03, 2013
4 Suggested Answers
  • 246 Answers
SOURCE: Husqvarna looses power after 10-15 min.
Hello Matt:
From your Description it Sounds like Either the Gas Cap is Not Venting the Tank, the Exhaust Port/Muffler is Restricted or the Rings are Worn Out and Require Replacing.
Make Sure the Gas Cap Allows Air into the Tank.
If the Gas Cap is Good, then
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
If the Exhaust Port and Muffler are Clear, then Most likely the Rings are Worn and Require Replacing.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
#1 Taper
  • 1041 Answers
SOURCE: Husqvarna 323L gas trimmer runs & starts great
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Posted on Jun 07, 2009
#1 Taper
  • 1041 Answers
SOURCE: Husqvarna 323L Line Trimmer - Runs for about 5-10 seconds,
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwillneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to seedaylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 26, 2009
Why does husqvarna 123hd60 bogs on revs
Mix up some "carburetor & fuel injector cleaner" in a batch of fuel, Nathan, at the rate specified on the bottle of cleaner. Run it through the hedge trimmer just like normal fuel. For right NOW, you can use the choke to keep the trimmer running. As the cleaner works, you should need less & less choke to keep it going.
It may take a while.
Next time you store that trimmer for winter, drain it fully and run it until it dies from lack of fuel. Then it won't form varnish on the carburetor jets over the winter - that varnish is what's causing your problems now.
Aug 04, 2014 | Husqvarna 123hd60 Handheld Dual Sided...
Echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Nov 26, 2013 | ECHO, Inc. 20 In. Double Sided Hedge...
Bogs down after warming up
check exhaust port first. then carb adjustments, then either crankshaft seals or carb needs replaced... You cannot adjust carb, it has to go to a certified center for this procedure... Thank the EPA for this B.S. and no you cannot by the adjustment tools on Ebay.
Nov 26, 2013 | Echo Garden
55min run 323l trimmer
Check the fuel filler cap, there is a breather in the top if this is blocked it will create a vacume in the tank, try leaving the cap loose and see if the problem has gone, if not then this is an ignition unit issue, replace the ignition unit.
Jul 13, 2013 | Garden
Remove husqvarna 323l trimmer head
I'll send you a link to the owners manual, its all shown in there.
Aug 06, 2012 | Husqvarna 323L
Where do I get a new ignition coil for my 323L trimmer
Are you sure its the coil.? Have you tried relesing the fuel cap and trying it again.? Could possibly the fuel tank vent, creating vaccum in the tank and starving the engine.
Jun 28, 2012 | Husqvarna 323L
Husqvarna 323L gas trimmer runs & starts great but looses power after 10-15 min and if you give it gas it dies. let it cool and it runs great for another 10-15min. trimm has less than 5 hours
Jim
Jun 07, 2009 | Husqvarna 28cc Gas Line Trimmer
323L Husqvarna trimmer
This sounds like the carb needs to be adjusted like it is letting to much fuel into the cylinder. There is supposed to be fuel and air mixture in the cylinder to make it fire. If there is to much fuel what will happen is that it will just build up in there and the air wont get hot enough as it compresses to start the engine.
May 21, 2009 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 28cc Gas Line Trimmer Logo
114 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
