Question about Sharper Image 8021 700 Watts Juicer
The juicer won't turn on. Everything was put together but when I plugged it in, nothing happened.
Why does juicer not start when assembled and plugged in?
It has a 10 year warranty, but check the instructions as there are bound to be safety features on it to stop it working unless properly locked together.
Omega BMJ330 Commercial 350 Watt Stainless Steel Pulp Ejection Juicer...
Review
Omega BMJ330 Review JuicerReviewsDirect com
Manual is here. Doesn't look as if there are any safety interlocks in the drawings. Aha, there is a safety lock! It is good to read to the end :>) Page 23 states;
IF YOUR JUICER ISN'T WORKING
If the latch arm on the right side is not secure and properly in place the juicer's safety switch will not engage. Therefore, the juicer will not work. Assemble the juicer properly.
https://www.omegajuicers.com/media/manuals/EFS_BMJ330_390_Manual_JUNE2014_web.pdf
Aug 22, 2014 | Omega Juicers BMJ330
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
My juicer won't turn on
May have a short in wire. Can you replace the power cord?
Feb 05, 2014 | Juicers
Hello, and thank you for your time. The juicer was given to me 2 months ago and it's brand new. As of today, some how l can not get it to work. l turned the nob to on, but nothing happens. l opened the...
you have to twist the top round so that the switch is pressed in place so the power can be turned on, from new it takes a few times to get it to click in place this is the safety device so it cannot be turned on by mistake.
Aug 04, 2017 | Hamilton Beach Big Mouth Pro 67600 820.27...
Jak lalanne not working
Regarding Jack Lalanne juicer. After making sure nothing clogs the blades., make sure the stainless bar is on the correct slots on top of the juicer, left and right. It has a safety switch that when its not closed properly, it won't run.
Jan 31, 2009 | Jack Lalanne Power Juicer 250 Watts
Juicer will not run
Make sure the stainless bar running across the top is snug on the left and right groove. It has a shut off switch when not installed properly.
Jan 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Owners Manual
Bought an open box Waring JEX 328 from Linens and Things (going out of business so need to return quick if it is defective) and plugged it in and nothing happened! So now trying to figure out if all pieces are in their correct place. There are two small plastic pieces that seem to go together a smaller angled black piece and a long light plastic piece. Any thoughts? Is there an auto kill switch on these if something is not assembled right?
Nov 22, 2008 | Waring JEX 328 Health Juicer
The pulp collection receptacle has a tiny clear plastic button on the bottom. If this has broken off (it happens often) the machine won't turn on. The button must be present to depress the safety switch at the bottom of the machine. If everything else is properly assembled and the machine won't turn on, this is probably the cause. Check the bottom of the pulp collection receptacle to see if the button has broken off. (picture #2) If so, replace it with a piece of pasta or a tiny piece of wood. Sounds silly, but it works. The safety switch at the bottom of the machine must be depressed before the machine will run.
Nov 04, 2008 | Jack Lalanne Power Juicer 250 Watts
Darn thing STILL won't turn on
There is a little knob on pulp collector that pushes in a switch, probably to assure the unit is assembled before operation. Mine broke off. I opened bottom of unit and used electrical tape to permanently engage the switch. The Juicer now works. I consider it poor construction that such an important part of the operation of the unit is able to break off and poor customer relations that there is no help for this on their web site. I have used it only a handful of times and the unit has mostly been in storage and has not been abused.
Jun 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Motor not working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Apr 16, 2007 | Champion G5NG853S Household Juice...
Sharper Image 8021 700 Watts Juicer Logo
352 people viewed this question
Top Sharper Image Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Sharper Image Juicer Expert? Answer questions, earn points and help others
