Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Pump was running last night / checked on pump this morning and not working. When I gott home this evening went to re start pump and still will not come on.
Its probably dead. they burn out very quickly. call intex
Posted on Apr 11, 2011
Car won't start
Have read this twice and based on what you have indicated I think that maybe you have an intermittently operating fuel pump - sometimes it works and sometimes it does not. And while you are it, U might just want to check to make sure that the pump is always being energized -see if there is a loose connection somewhere that could result in the pump not running at times. If you have access to a voltmeter have your husband hook it up to the hot line and a good ground and have the meter in the car next to you. The moment you turn the ignition on the meter must register 12 volts or more. And once on, there is no cutting off - it stays at 12 volts at all times and any excess fuel pumped is returned back to the gas tank. Good luck.
Aug 26, 2015 | AC Cars & Trucks
Drove home last night and this morning my impala 2003 wont start
Security. Turn the key to run. Let it sit for ten minutes, off for thirty seconds. Then try to start. Do this three times for a relearn. Don't try to start.
Sep 07, 2014 | 2003 Chevrolet Impala
Engine turns over but will not run
Are you getting spark to the plugs ?
Have you sprayed starting fluid into the intake ?
Dec 10, 2012 | Cars & Trucks
I have a 1998 chevy s10 with 195000 miles, drove home from work last night went out this morning started right up died out 45 seconds later, now wont start, battery is fine,and fuel pump is still making...
98 chev pickup s10 put gas in the gas tank drove it about 2days and the check engen light came on had it check mech said it was the gas cap replace the gas cap the light back on now what help
Dec 02, 2010 | 1998 Chevrolet S-10 Pickup
Car is stuck in park. Wife drove home last night
TRansmission went on the car you may have to buy a new transmission
Mar 19, 2010 | 2001 Pontiac Grand Am SE
1997 mpv mini van runs great. While traveling i drove from SC to Atl GA....parked and went into motel for evening...the next morning i had very difficult time getting it re started....Like it was not...
I think you should check your battery and alternator.If they both check good you may have a battery draw,something draining the battery over night.Check your doors make sure they are closing like they should.
Jul 28, 2009 | 1997 Mazda MPV
Won't start
check your fuel pump relay.. if it is not disengaging after the pressure has reached its max after turning the key off, then the relay is probably faulty.
Mar 10, 2009 | 1989 Chevrolet Beretta
Wont start after setting
Remove air cleaner Spray carb with carburetor cleaner inside and out let dry try to start..
Probable cause dirty carb or air cleaner choke not set properly or needs adjustment
and cleaned>>Charg battery ans check fluid level fill only with distilled water
Jan 30, 2009 | 1997 Chevrolet Suburban
Truck wont start
Check the fuel pump run relay under the hood in the power distribution box, it may be sticking and not allowing the pump to run after the key is released on start up, crank and run are 2 separate circuits on the pump.
FixYa.com claims they have factory repair manuals, they have nothing of the sort, this is not to say some experts may have manuals, we do, but we work from home and in most cases have a small library. Experts are not employed by FixYa.com, we help free of charge as much as we can with the general automotive knowledge we have learned while working as auto technicians, specific test values, repair procedures and illustrations are unique to each car line, these are not in most cases available to us. Thanks for using FixYa!
Oct 25, 2008 | 1999 GMC Suburban
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
173 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
