Question about Carrier Heating & Cooling
Indoor blower not working Bad circuit board in furnace model HK42FZ011- needs to be replaced Carrier model 58WAV155-12120 serial # 3295A09613 Where can I get this board and do you need a professional to install it?
    Genius:
  • 2,035 Answers
You can use this link:
http://www.repairclinic.com/0047_16.asp
Good luck...
Posted on Aug 06, 2008
Blower on furnace not working
Make sure your circuit breaker hasn't tripped to your furnace. Make sure your door panel to your furnace is installed right. There is a door switch that has to be depressed to complete the circuit. Also turn thermostat to fan on and see if fan comes on. If those two things don't work it will have to be trouble shot by a respectable HVAC technician. Could be your Indoor blower capacitor, defective fuse on circuit board or defective circuit board or defective blower motor.
Dec 06, 2013 | Heating & Cooling
FURNACE LITES UP RUNS FOR 2 MIN. SHUTS OFF GAS.PAYNE
Carrier had a recall years ago on the HK42fz004 & I believe the 008 models because of intermittent problems like yours. Sounds like you need a new board
Jan 02, 2013 | Carrier Furnace Control Circuit Board...
Carrier furnace HK42FZ011 wiring diagram
carrier plas 90 bryant Gas Furnace wont light - LED has 2 blinks what can be
Dec 25, 2012 | Heating & Cooling
Wiring diagram for carrier HK42FZ011 circuit board
Wire for wire if you are a novice. The schematic should be on the blower door just in case you get lost. I myself have changed hundreds of them and just undo the wires since I know where they go.
Jul 17, 2012 | Carrier Furnace Control Circuit Board...
No power to ac indoor fan motor
sounds like you might have a bad control board. try putting a jumper wire on the control board low voltage terminals R and G your fan should come on and run if you have 120v power to fan motor. double check that you do have 120 leaving board and going to motor. if no 120 bad board if you do have 120 bad motor. if it is the board it likely has a bad blower relay which is common in amana models and goodman equipment.
Sep 13, 2009 | Amana Heating & Cooling
Indoor blower motor not responding. checked 24
if you have 24v between the c common terminal and g green/fan terminal on the board in the furnace and the fan does not come on, then it is the circuit board.(as long as you know the fan works)
Jul 14, 2009 | Heating & Cooling
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 58MVP; Blower on, no heat. Themosta at 75, temp at 69 and furnace still does not come on. Fault code 12
A code 12 is "Blower on after power-up" Try resetting the furnace with either the Emergency switch or circuit breaker. If it continues, you may need a new control board.
Nov 28, 2008 | Carrier Heating & Cooling
5 min time delay for central system blower unit not reset whe serviced
Make sure to turn off the furnace at the breaker or disconnect switch before attempting to touch the electronics of the furnace. Also look around the furnace for an owners manual. The manual will have the process for changing the blower off delay. I have given you a pretty generic process below. If you need more specific directions I will need your model and serial number. If your furnace is new enough I may be able to find your manual in our system. Good Luck:)
In most cases a circuit board model will have a small (1/4 inch x 1/8 inch) black, plastic jumper. I think I remember that some can be red also. Anyway This jumper is plugged on to two vertical prongs coming from the board. There are other bare prongs on either side of the jumper. If you look at the writing on the board you will see different numbers ranging from 60 to 190. These numbers represent seconds in time. You can change this jumper to match the seconds that you want for the blower off delay.
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
149 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
