Question about Mitsubishi CP3020 Thermal Printer
Mitsubishi printer 3020dae. thin solid white line along length of print. always in same place. Have repalced ink ribbon and no change.
    Master:
  • 344 Answers
You may either have a bad connection in the thermal array or dirt/dust on it. If you have never performed maintenance on the device you can find an easy button here http://www.cleanteam.com/Thermalcards.html
Otherwise if you feel brave, open her up! Turn off the power first of course. Grab a micro-fiber cloth (like for photo lens cleaning) and a bottle of at least 99% isopropylene alcohol.
Dampen the cloth with the alcohol (not super saturated) and with moderate to gentle pressure swipe the thermal strip (the cover is usually made of glass, be careful not to break it.) Repeat with a clean area of the cloth, dampen with alcohol, swipe. Do this several times and let sit to dry for at least 5 min.
Put her back together and you should be good to go!
Posted on Apr 05, 2011
  • Bryan Daugherty
    Bryan Daugherty Apr 14, 2011
    After viewing the solution again it seems that fixya's imaging doesn't work... this is the broken image in the reply.
    http://i34.photobucket.com/albums/d101/a...
Red ink doesn't print properly
it could be the print heads are clogged i had the same problem with a printer i had a few years back that wasn't used for a week i took it into a printer place near me paid 20 pounds had the printer serviced and it came back perfect
Feb 11, 2014 | HP Photosmart D7160 InkJet Printer
Printing lines on cards
Hello Richard,
Sorry for the delay in replying to your request.
You may have already resolved your issue by now.
The advice below may help others with the same issue though.
In the case of a damaged (scratched) printhead, the lines always run along the cards longest length (landscape), and are always in exactly the same place.
They are normally White, and usually very thin (just a few pixels wide). You would also see the line on the used dye film too by unwinding some film from the take-up spool (at the front of the printer).
Sometimes in the case of older out-of warranty printers, it is easier / cheaper just to avoid that are of the card using the card design. The image can also be rotated 180 degrees in the driver's Printing Preferences. However, if the card design has a solid colour background, or the White line is in the centre of the card, printhead replacement may be the only option.
Depending on which Rio model you have (Rio, Rio 2, Rio2e, or Rio Pro), different printhead assemblies are available as a field replaceable unit. Part numbers are below;
Magicard Rio - FG/M9005-794
Magicard Rio 2 / Rio 2e - FG/M9006-630E
Magicard Rio Pro - FG/3652-0160
All are available from your local Magicard dealer / reseller.
Prevention is better than cure;
  • Replace the sticky cleaning roller in the cleaning cassette as regular as possible.
  • Only use good quality blank PVC card stock (no sharp edges, or burrs)
  • Clean the printer regularly using the appropriate cleaning kit;
    Rio, Rio 2, Rio 2e (Cleaning kit part number: M9005-761)
    Rio Pro - (Cleaning kit part number 3633-0053) *
    Rio Pro - (Sticky roller kit (5 rollers +metal shaft) - 3633-0054)*
    * A sticky cleaning roller is supplied with every new dye film
Kind Regards,
MC.
Dec 03, 2013 | Magicard Rio Card Printer
We have been getting white horizontal lines on our documents. Both print heads were recently replaced and that did not solve the problem. What part is needing replaced?
I had this same problem and none of the printer services (clean printhead, align printer, calibrate linefeed) fixed the problem. After trying every solution that I found on the internet with no success I was able to fix the problem by cleaning two critical parts of the printer.
1. Turn off the printer and open it as though you are going to change the printheads.
2. Towards the back of the printer you will see a thin clear plastic ribbon that has very small black lines on it. Very, very, very gently clean this ribbon. I used a lint free cloth and some glass cleaner. Spray the cleaner on the cloth and slide the cloth against both sides of the ribbon. Do not pull on the ribbon. This ribbon is used to tell the printhead how far it has moved from side to side.
3. Next locate the silver bar that runs across the back of the printer. This bar is used to feed the paper through the printer as it is printing a document. On the left side of the bar you will see some plastic guides that hold the bar in place. On the outside of the plastic guides you should see a clear plastic disc made of the same material as the ribbon above. This disc also has very small black lines on it. Again very, very, very gently clean this plastic disc. This disk is used to tell the printheads how far it has travelled down the page. This is the one that was causing the problem. The dust or dried ink or whatever was on the disc was causing the printer to incorrectly calibrate the linefeed and was causing the white lines to appear on my documents.
4. Use the "calibrate linefeed" function of the printer services to recalibrate the linefeed and the white lines will hopefully be gone.
Jul 26, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Yellow light keeps blinking wont print
If it's the down arrow that is blinking, mine was doiong the same thing. The problem in my case was that the sensor ribbon was dirty. The ribbon tells the ink cartridges what position it should be in. This ribbon is the thin one that the ink carier glides along, not the white ones attached to the carrier. Take a damp paper towel and clean both sides of the ribbon- there will be a lot of black gunk that comes off. Mine worked fine after I did that, I hope yours will, too. Good luck!
Feb 21, 2011 | HP DeskJet 5150 InkJet Printer
When I calibrate colour Magenta and Lt.Cyan fail to print
boil the head printer in a hot water for ten minutes and wiped it smoothly
Aug 09, 2009 | HP DesignJet 130NR InkJet Printer
Printhead leaves impressions but no print
Sounds like you've run out of ink? If not then the ink has become dry and clogged the head.
Try using a alcohol solution (white spirit or a strong liquor like vodka will suffice) with a piece of paper towel to clean the head of the ink cartridge, then try printing a few times until it works well.
Otherwise, sounds like the cartridge needs repalcement.
Jul 02, 2009 | Datamax DMX I-4206 Printer
Prints faint and cuts of the top and bottom of some lines
The ink in the cartridges has dried up. Replace them.
Feb 01, 2009 | HP DeskJet 950c InkJet Printer
Document print quality
A solid line sounds like a jet (in the print head) always on. Replace the print head (<$50 on eBay).
A white line (no ink) sounds like a clogged print head or a burned out jet. Replacing the print head will fix either one. If it is clogged, you might be able to clean it but this procedure is complex (soaking or special cleaners). Read about cleaning in other posts.
Jul 30, 2008 | Canon PIXMA MP750 All-In-One InkJet...
FARGO PRINT HEADS
If you have a solid white line running the entire length of the card (think landscape style) you probably have a bad print head. I always tell people if you could place a ruler along the line and it is perfectly straight along the ruler, then that is a classic example of a bad print head. Check the MFG warranty for replacement or purchase.
May 17, 2008 | Fargo DTC550 Thermal Card Printer
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
Mitsubishi CP3020 Thermal Printer Logo
110 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
