Question about Terapin TT-2600 DVD Player
The last DVD I played is stuck in the player. I cannot eject it. It makes the right noises and then the "open" sign changes to "load" and that is it!
  • Terapin Master
  • 6,993 Answers
I think the DVD inside the player is busy, that's why it is refusing to eject.
Turn of the player, turn it back on, wait for about a minute for the DVD inside the player to load, after that press the eject button once and the DVD should eject.
If it still doesn't eject please let me for further directions.
Take care....
Posted on Apr 05, 2011
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
My dvd recorder makes a buzzing noise wont power up eject or play
some thing might have stuck inside your DVD player. some internal wires.. attached may cause this problem. if you are aware of the wires and if you can handle it after opening it , then just open and check. if not, i would suggest you to take it to someone who is aware of that.
Nov 02, 2010 | Cyberhome DVR 1600 DVD Recorder
URGENT! DVD not ejecting or playing.
It seems you will need to open the damn thing, or search for a tech, verify your warranty, dont void it.
First you can try to move a little bit the dvd, unplug and plug, change disc, ieverything that can move a part inside the dvd must be pressed, surely is stucked between the play and the open stage.
Jul 17, 2010 | Pioneer DV-515 DVD Player
Sony dvd/video combo dvd stuck inside
will it play the disc? try giving the door a little help when ejecting sounds like a slipping drive belt.farr64
Apr 29, 2009 | Sony DVP-NS305 DVD Player
DVD Stuck in player
There is nothing you can do with this problem unless you are able to repair DVD players, the loading mechanism of any DVD player is very complicated, chances are a small part has broken. Call the dealer and ask for the phone # of the repair center they use, call them for an estimate, don't go through the dealer, they will double the repair bill from the radio shop.
Oct 14, 2008 | 2003 Lincoln Aviator
DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Jun 19, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Dvd wont eject
Make sure the DVD player is level, and that there is nothing stuck inside. You might have to GENTLY nudge the door, with a careful prying motion. If it still won't eject, and you feel daring, you can open the device with the POWER OFF, (Don't lose screws), and see if it there is an obstruction. This last option will most probably void the warranty, so only do this if you are comfortable.
Sep 07, 2007 | Oritron DVD600 DVD Player
Terapin TT-2600 DVD Player Logo
206 people viewed this question
Top Terapin Televison & Video Experts
Are you a Terapin Televison and Video Expert? Answer questions, earn points and help others
