Air conditioner for home. sometimes it starts and puts out cool air then sometimes the fan runs but no cool air?
  • 182 Answers
Check the charge.
Posted on Aug 06, 2008
I have a goodman cple42-1 The fan motor outside was not running and I was able to get it started but the house wont cool now. air is blowing but not cold.
the capacitor is possibly bad the indoor fan uses its own capacitor while the outdoor fan and compressor share a capacitor
Jun 29, 2012 | Goodman CPLE24-1 Air Conditioner
Tip
Air Conditioners Cooling Tips
  • Whole-house fans help cool your home by pulling cool air through the house and exhausting warm air through the attic.
  • Set your thermostat as high as comfortably possible in the summer. The smaller the difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be.
  • Avoid setting your thermostat at a colder setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing your power use.
  • Avoid placing lamps or TV sets near your air-conditioning thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
  • Plant trees or shrubs to shade air conditioning units but not to block the airflow. Place your room air conditioner on the north side of the house. A unit operating in the shade uses as much as 10% less electricity than the same one operating in the sun.
  • on Sep 21, 2010 | Heating & Cooling
    Unit makes a loud rattling noise when operating
    Hello, most likely the fan blade is either loose or cracked at the hub causing the blade to hit the fan shroud. You will either have tighten the fan blade or have to get a replacement.
    Jun 20, 2012 | Kenmore 71121 Air Conditioner
    To turn on the air conditioner, on the thermostat do you click it to Auto and then on the other side click to Cool? Or do you click on Fan and Cool?
    If you put the fan to auto, the fan will run only when the compressor runs. the other position it will run untill you switch it back to auto. Then cool unless you require heat at night or in the morning, usaually when I start cooling season the heat stays off.
    Jul 05, 2011 | Honeywell Heating & Cooling
    The fan on outdoor unit sometimes starts normally, sometimes starts slowly and will get up to speed with a push or sometimes will not start at all. Loud hum when slow or stopped. Cools normally when it...
    SOME MODELS HAVE A TEMPERATURE DEVICE THAT CONTROLS THE FAN WHEN REAL HOT IT WILL CONTROL THE SPEED OF THE FAN WHEN COOL OUT THE FAN WILL VERY FROM FAST TO SLOW DEPANDS ON THE HEAT BEING PUT OUT BY THE OUT SIDE UNIT IF THIS PROBLEM OCCURES DURING BOTH HOT AND COOL NIGHTS THE FAN MAY BE GOING BAD
    Aug 22, 2009 | Heating & Cooling
    Condenser fan running backwards on heat pump
    I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
    Jun 13, 2009 | Goodman CKL24AR24 Air Conditioner
    Home AC Compressor starts asynchronously with cooling fan
    Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
    Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
    Heating & Cooling Logo
    53 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
