Question about Gateway Computers & Internet
Conexant modem driver? gateway MX7315 N3464J1016035 NOTEBOOK. WHAT CHIP#?
    Novelist:
  • 202 Answers
If u need drivers for the modem just search in google or else try in www.driverguide.com
just mention u r laptop model number and brand name
Posted on Aug 06, 2008
Gateway mx 6421 win764 driver issues
You could, drivers are based on manufacture. Like Realtek is a common maker of audio chips, and sometimes distributors use a popular motherboard.
You may have plateaued at Vista, by try the Troubleshooting Compatibility with Vista 64 drivers before you roll it back.
BTW - This happened to me with Win 8.
Oct 26, 2012 | Gateway MX6421 Notebook
Audio modem failure when installing in compaq 772tu
Hi, I understand that you are unable to install Windows XP audio driver for your Compaq Presario 772TU Notebook.
This model was built with Conexant Audio and Modem Chip. For that, you may first need to install Microsoft UAA driver and then, install appropriate drivers.
Download and install UAA drivers from here:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
Conexant High Definition Audio Drivers here
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
This will create a swsetup folder in c drive ("C:\swsetup\sp34200")
Installing Audio drivers may result in an error. But continue with the following steps to get the audio driver installed correctly.
Open the Device Manager:
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp34200 folder and select the .inf (wis30b2a) file and click open and Continue with the onscreen instructions.
Similarly install Modem Drivers:
Download and install Conexant HDAUDIO Soft Data Fax Modem with SmartCP from here:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33890.exe
1.Right click on "Modem device on High Definition Audio Bus" and click Update driver.
2. Select "Install from a list or specific location"
3. Click Next. Then select "Don't search, I will choose the driver to install"
4. Click Next and then select "Modem" from the list.
5. Click Next and then click Have Disk.
6. Click Browse C:\swsetup\sp33890 folder and select the .inf (wis30b2b) file and click open and Continue with the onscreen instructions.
Thanks,
Shiva
Dec 18, 2010 | Compaq Presario 700 470024-192 Notebook
I don't have driver usb hfs modem, how toget the driver ????
1. Where can I get drivers for my Rockwell/Conexant HCF or HSF modem for Windows XP, or I am having difficulty installing my modem in Windows XP?
Conexant has worked with Microsoft to ensure that many PCI modems are supported using a generic data/fax driver that is available on the XP distribution CD, therefore in the majority of cases your modem should automatically be detected and the generic driver correctly installed. Run the List Modem application (listmodem_app.zip) found on the Modem Driver Assistance page to find out if your modem is supported in the inbuild driver on WinXP. If the answer to "WinXp Inbuild Support" is yes, then your modem will work after upgrading to WinXP even when you run the compatibility test before upgrading and you get a warning. However the XP distribution CD does not have drivers for Conexant USB modems or modems that interface to the PC using the AC-Link bus. The AC-Link bus is primarily used in notebook PC's and some desktop PC's. In these cases it is necessary to download the correct driver from the manufacturer before upgrading to XP. If you get the message shown below and you have a notebook PC use the links below to obtain XP drivers.
Example XP Error Message: xperror.gifIf you do not have one of these PC's it means that the current driver that you are using in your previous operating system is not compatible with Windows XP, however if you have a PCI modem it is very likely that your modem will be supported by the driver available on the distribution CD and will work when you upgrade to Windows XP, and you should proceed with the upgrade. Links to OEM Drivers: carrot.gifSony VAIO Systems
carrot.gifGateway Systems
carrot.gifHP
carrot.gifDell
carrot.gifToshiba
carrot.gifLegend
carrot.gifAcer
carrot.gifNEC
carrot.gifFujitsu
carrot.gifTwinHead
carrot.gifMaxData
Jul 27, 2009 | Computers & Internet
Gateway MX7315 Will not power up.
Check the connection between your the power bezel (the plastic piece with the power button) and the motherboard. This has a tendency to come loose whenever you take laptops apart.
Dec 21, 2008 | Gateway MX7315 Notebook
Need drivers
First, of all, we need to check whether your Notebook is having Conexant AC-Link audio or Conexant High Definition audio or not.
Try installing the Conexant AC-Link Audio drivers by downloading them from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32272.exe
Save the driver file on to the Hard Drive of the Notebook and double click to install it once the download is completed.
However, if you get any errors with installing the file, I recommend you to delete that file and try installing the Microsoft UAA Drivers and HD Audio Drives.
Download the Microsoft Universal Audio Architecture(UAA) Drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Save the file and double click once it is saved to install the file.
Restart the Computer once the installation is completed.
Now, download the Conexant High Definitino audio drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32864.exe
Save the file and double click it to install the audio drivers.
Similarly, there are two types of Modems installed in DV1000 series Notebooks and below are the drivers for the same.
Conexant AC97 Soft Data/Fax Modem with SmartCP Driver :
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32273.exe
Conexant HDAUDIO Soft Data Fax Modem with SmartCP :
(You need to have the Microsoft UAA Drivers installed before installing this modem drivers)
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32210.exe
The Mass Storage Controller in the Device Manager indicates the Card Reader integrated in the Notebook and below are the drivers for both types of card readers available for your series of Notebook :
Ricoh 6-in-1 Card Reader Driver :
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32126.exe
Texas Instruments Media Card Reader Driver :
ftp://ftp.hp.com/pub/softpaq/sp33001-33500/sp33439.exe
Hope this helps...
Aug 26, 2008 | HP Pavilion dv1000 Notebook
Audio connexant driver installation
HA! Gateway is the WORST! They tell you to download the drivers for your notebook...they install and then code 10!!!!
I'll cut to the chase with the solution, but I could go on for HOURS about how bad they are! I wish we could all BILL them for our time and frustration! If this solution helps you, think about making a donation to our dog rescue (link below).
http://www.petfinder.com/shelters/midwestanimals.html
I took my n/b to the Geek Squad...after 3 hours they still did not have the sound fixed!!!
FOLLOW CLOSELY!
For people having the same audio problem (Conexant Ac-Link Audio Drivers, Realtek) here is the fix.
“1. Install Realtek Audio driver (WDM_A380 or WDM_A381, doesn’t matter).
2. Reboot
3. Download and try to install the Conexant AC 97 audio driver. You can get the one from Gateway (D00245-001-001 driver), or any other manufacturer that uses this chip in the notebook. Pay attention to where it stores the files. For instance the Gateway driver uncompresses to c:\cabs\directory name.
4. Go to device manager, find the Realtek AC 97 audio item under “Sound, video, and game controllers”. Right click on it and select UPDATE DRIVER
5. Select NO if it asks to connect to Windows Update, click NEXT
6. Select “Install from a list of specific location” and click NEXT
7. Select “Don’t search. I will choose the driver to install” and click NEXT
8. DE-select “Show compatible Hardware”. CONEXANT should show up under manufacturer since you tried to install the driver earlier.
9. Click on CONEXANT on the left, then select “Conexant AC-Link Audio” on the right and click NEXT
The driver will install. It may ask you for the location of some files, point it to the directory the Conexant driver uncompressed to in step 3.
Reboot, and you should have working audio!”
Dec 01, 2007 | Gateway MX6438 Notebook
Computers & Internet Logo
32 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
