Question about Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt pony and the drive belt to engage to blades keeps coming off. I have replaced the belt and the pully what else could it be?
    Brigadier General:
  • 3,911 Answers
Well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Posted on Apr 06, 2011
  • Jason Odermatt
    Jason Odermatt Nov 07, 2013
    Think this is my problem also
How to adjust drive belt on troy-bilt pony tractor
pony lawn mower? replace the drive belts.
Mar 04, 2017 | Troy-Bilt Garden
Why does my Troy Bilt Pony Mower deck keep running after it is disengaged
-The belt is too tight. It should be free when the engine is running.
-Adjust it. It'll take care the problem. (I'll say it'll need about 3/4" to 1 1/2 clearance)
Good luck
mai
Sep 01, 2014 | Troy-Bilt Garden
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
Need belt diagram for Troy bilt Pony. The drive belt just broke and I need to 1, buy one and 2, replace.
hi im having trouble on my troy belt riding mower it is a 42 inch im tring to change the belt we have it on but it not right please help me
May 15, 2010 | Troy-Bilt Pony Garden Tiller
My troy built keeps eating the forward drive belt?
Had one do that not long ago. The problem was the idler pulley that pushes against the belt when you pull the engage lever on the handle was not lined up with the belt. I just bent the idler bracket to line up the pulley with the belt. Maybe this will help, assuming you have the same model.
Jun 29, 2009 | Troy-Bilt Pony Garden Tiller
Ineed the diagram for a 42 inch deck troy bilt
We I disengage the blade belt always comes off its to loose I have had the number checked they say its the right belt but its so sloppy
Apr 26, 2009 | Garden
Replace belts
It is pretty easy to change the belts. The correct size is the problem. I bought some replacements for mine and found they didn't just quite fit. I finally got them from Troy Bilt so they fit correctly. Remove the two fly nuts to the safety shield over the belts. Next remove the cotter pin that holds the idler pully to the control shaft. This will now allow you to swing the idler out of the way so the belts can be removed. A little twisting and turning and they will come out and go back in without a problem. Reconnect the idler pully and pin and make sure it is adjusted properly for operation then replace the safeth cover. Good Luck, RAC
Apr 02, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt 175HP Manual 42" Riding Mower Logo
1,978 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
