Question about Magic Chef CTB1502AR Top Freezer Refrigerator
Freezer Coil freezing over. - Magic Chef CTB1502AR Top Freezer Refrigerator
  • 96 Answers
You have either a defrost timer, defrost thermostat or defrost element that is bad.Before you defrost, use an ohmmeter to check the defrost thermostat to see if it is closed. If it is , defrost and check the defrost element for continuity. If it has verry little resistance , you have a bad defrost timer.
Posted on Apr 05, 2011
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
MAYTAG MSD2734GE side-by-side fridge/freezer. The freezer coils on a regular basis (3-6 weeks intervals) will freeze. We will have to remove the coil covers and manually defrost them before it will...
I have written tips pertaining to each of those 2 issues
Drian blocked tip...http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
Evap. coil freezing up tip...http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
i have 2 pictures in the coil freezing up tip and they always for some reason post incorrectly so here they are..oldtech2332_43.jpgoldtech2332_44.jpg
Aug 22, 2011 | Maytag MSD2734GE Side by Side Refrigerator
The freezer side of the unit will freeze until it freezes over and will no longer keep the freezer frozen. The freezer then has to be defrosted so it can freeze again.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 08, 2011 | Maytag Freezers
The freezer fills with water and overflows about once a week.The food is partially frozen and the ice is clear and wet. The fridge is cold and no problems but the freezer doesn't fully freeze and water...
your evaporator coil in the rear area behind the freezer back panel is frozen over with ice and the coil can no longer deliver cold air due to ice blocking the air flow from the evaporator fan,remove this rear panel,defrost it with a hair dryer,check the defrost heating coil for continuity,they go bad regularly,if not the heater coil under the evaporator coil,it may be the defrost timer in the refrigerator section of the unit that powers the defrost coil that needs replacement
Jul 25, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
The coil in the freezer is freezing up no air flo
either defrost timer, t-stat or heater is bad. either way it is worth repairing.
Feb 12, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The freezer will not freeze or keep its
Check to condenser coil and make sure it is clean and the fan near it is running when the compressor is on. Check for ice build up in the freezer. If the evaporator coil is iced up the box will run warm. It may be a defrost problem, a dirty condenser, or a refrigerant issue.
Nov 01, 2009 | Continental Freezer Wide Freezer low temp...
Turn off the refrigerator.Remove the freezer shelves/bins and rear panel.
Take a hair dyer and thaw the ice completely. The defrost heater will be across the bottom of the freezer coil. The defrost thermostat will be attached to a refrigerant coil at the top of the freezer coil.It is about the size of a quarter and 1/2 inch thick.There will be wires from top to bottom on the sides of the coil.
May 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer coil keeps freezing up. I replaced the
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Apr 29, 2009 | Kenmore Refrigerators
Freezer coil and back of freezer full of ice, never defrosting
Low on freon or the blower fan has stopped
Apr 11, 2009 | Refrigerators
Magic Chef CTB1502AR Top Freezer Refrigerator Logo
168 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
